vr5510 has the vdig and vana pins , how to control both pins in application. i see the -0.3 ~1.65v
699 次查看
MarkWub06227
vr5510 has the vdig and vana pins , how to control both pins in application. i see the -0.3 ~1.65v spec in datasheet, customer use it how to connect voltage.
684 次查看
ErikaC
Pins VDIG, VANA, VDDIO require at least typical value 1 x 1 μF, 16 V, X6S capacitor at each output.
645 次查看
MarkWub06227
i see -0.3 to +1.65v spec in datasheet, how to output 16v, what’mean x6s capacitor.
