UPM values update
UPM values update
4,402 次查看
m_syed_ahmed
We are working on the MPC8248 custom board. We have different timing valued SRAM chips. How to update the timing values for UPM devices? How does the UPM values obtained?
标记 (2)
8 回复数
4,313 次查看
yipingwang
Please refer to "11.6.2 Programming the UPMs" in https://www.nxp.com.cn/docs/en/reference-manual/MPC8272RM.pdf.
4,094 次查看
m_syed_ahmed
Is it possible to re-configure the UPM values at kernel level?
4,028 次查看
yipingwang
Please refer to the following files in the BSP.
arch/powerpc/sysdev/fsl_upm.c
include/asm-powerpc/fsl_upm.h
4,024 次查看
m_syed_ahmed
Am not able to find that file.  Can you tell in which kernel version those files were available? Also, we are working on 2.6.20. Is it possible to port those files to this version?
4,007 次查看
yipingwang
Please refer to the following.
./drivers/mtd/nand/fsl_upm.c
4,005 次查看
m_syed_ahmed
My kernel 2.6.20 doesn't have that file too. But I found that in the latest kernels. Is it possible to port that file to 2.6.20?
3,885 次查看
yipingwang
Please try to back port that driver file in your Linux Kernel.
3,885 次查看
yipingwang
