T1024:SPI BOOT SPI-CS# access STOP
1,223件の閲覧回数
kojimiura
When the T1024 is SPI booted, after the power is turned on, the SPI-CS # pin does not read the SPI to the end. It becomes HIGH level and U-BOOT does not start. For example, if the SPI read data is incorrect, will the SPI-CS # pin become HIGH? thank you.
0 返答(返信)
