Running Automatic Applications
1,845 次查看
narreddisivapra
             I am using MPC8323E-RDB board for Linux application development. I want to run my C application automatically right after boot-up. How can I achieve this on my board. Please, respond as soon as possible.
Thanks and Regards,
Siva Prakash Reddy N
标记 (1)
3 回复数
1,720 次查看
Pavel
It is common question for Linux.
See the following pages:
http://unix.stackexchange.com/questions/56957/how-to-start-an-application-automatically-on-boot
https://docs.oseems.com/general/operatingsystem/linux/automatically-run-program-on-startup
http://stackoverflow.com/questions/7221757/run-automatically-program-on-startup-under-linux-ubuntu
http://superuser.com/questions/685471/how-can-i-run-a-command-after-boot
http://www.linuxquestions.org/questions/linux-general-1/how-do-i-automatically-start-a-program-at-st...
Pavel Chubakov
1,720 次查看
narreddisivapra
Thank You for your help.
Now I wanted to remove terminal from my MPC8323E-RDB board i.e, it should not appear after boot-up, so what can I do to knockoff terminal.?
Please, Reply as soon as possible.
Thanks and Regards,
1,720 次查看
narreddisivapra
          Please respond to my query as soon as possible.
Thanks and Regards,
