Reprogramming DDR controller on PowerQUICC III
1,416 次查看
ConfusedInOR
Is it possible to reprogram the DDR controller on PowerQUICC III more than once after power-up?  Our system uses two bootROM (once factory installed, one field-upgradable) and the DDR is programmed in both (not necessarily with the same settings).  Is there a different program sequence needed the second time though?  Thanks!
0 回复数
