PQ2FADS-ZU u-boot serial issue
3,514 次查看
besoc
I am having a problem while trying to communicate with u-boot using serial RS232.
I am using putty to communicate with Freescale PQ2FADS-ZU on which i successfully flashed u-boot.
When the board boots up and u-boot shows its intial configuration and then the command line prompts appear, however before i am able to type any u-boot commandline commands the letter 's' is automatically sent a number of times , and perhaps thats what hangs up u-boot and it refuses to take any further commands. I am attaching a picture. Require your help. Stuck on this for days.
David
标记 (3)
3,462 次查看
ufedor
Please check the RS232 interface RXD and CTS activity.
Try to disconnect the RXD from the PQ2FADS-ZU internals.
