NOR response in x8 Mode instead of x16 Mode
singhawadhesh
Hi Team,
We were experimenting the NOR read and write operation in T2080rdb board through code-warrior. We were checking basic command in x16 mode as per datasheet, but it didn't respond for "QRY" command and all.
But when we tried same in x8 mode using the addresses w.r.t x8 datasheet, we are getting respond and able to access it fully.
As per schematic (Please refer the attachment), if BYTE# is high, it should only work in x16 mode but it's working in x8.
Please clarify the problem.
