MPC855T versus MPC860DP
steven_keeter
Is the MPC860DP pin for pin compatible with the MPC855T?  The MPC855T is now on LTB, but the MPC860DP still is ACTIVE.  Basically I need to replace the MPC855T with either a drop-in equivalent or do a PCB spin and port the code to the next closest variant.  Can someone please give me advise on this?  Also, if the MPC860DP can be used, how long will it be available?
