MPC8548E : PCB Layout Guidelines for Local Bus Interface signals
已解决
跳至解决方案
3,406 次查看
sagar_bn
Please provide PCB Layout guidelines for Local Bus interface signals of MPC8548E.
Should we follow any length matching for LAD[0:31] signals ?
Please also let us know about all the local bus interface signals for which layout guide has to be followed.
标记 (1)
1 解答
3,392 次查看
yipingwang
No general document is avialable. What is the device intended for interfacing?
Maybe some Freescale evaluation boards can be referred.
在原帖中查看解决方案
3 回复数
3,385 次查看
sagar_bn
We are using Local Bus Interface of MPC8548E for interfacing with many devices like NOR Flash, NAND Flash, NVSRAM, and two FPGAs.
These signals are running throughout my VPX standard board because of multiple components at different locations.
Please share if any Evaluation board file available.
3,297 次查看
yipingwang
Please find attached 8548CDS board design material. All people generated this files are gone. It is prepared by Mentor Graphics and it is not Cadence that board team are using. Simple put, no support for this file.
Alternatively, please refer to P4080DS material local bus design if the customer cannot make use of 8548 file.
3,393 次查看
yipingwang
