MPC8349 has no clock signal output
1,330 次查看
liven_deng
MPC8349 has no clock signal output, and then I use a wind tube to heat 8349, and it work ok.When the MPC8349 cools down and test again, it has no clock signal again. I have tested ten of the same batch, and they all showed the same phenomenon.When I replace an new batch MPC8349, it's ok. Could you tell me why, thanks.
标签 (1)
1 回复
1,254 次查看
ufedor
What is the signal name of the "clock signal output"?
Please provide the processor connection schematics for inspection as searchable PDF.
