MPC8349 has no clock signal output, and then I use a wind tube to heat 8349, and it work ok.When the MPC8349 cools down and test again, it has no clock signal again. I have tested ten of the same batch, and they all showed the same phenomenon.When I replace an new batch MPC8349, it's ok. Could you tell me why, thanks.
What is the signal name of the "clock signal output"?
Please provide the processor connection schematics for inspection as searchable PDF.
