Issue for MPC8245 flash program
1,641件の閲覧回数
gang_liu
Hi all, this week I met a very wild issue for MPC8245 board.  Now, I can download my program to SDRAM and it works very well, but when I use same ini.tcl to program the elf file to NOR flash, I met the below error:
I added my ini.tcl and connection log to below also, could NXP expert help me?  Thanks a lot
fl::target -lc "LC for Simple Flash"
fl::target -b 0x0 0x4b000
fl::target -v off -l off
cmdwin::fl::device -d "S29GL064S" -o "4Mx16x2" -a 0xff800000 0x1007fffff
cmdwin::fl::erase all
Beginning Operation ...
Performing target initialization ...
Downloading Flash Device Driver ...
Reading flash ID ...
Error: Failed reading return status. Can not read target memory at location: 0x000000000000000C.Please make sure that the chip selects are properly configured.
The CWPP response code is: CCSProtocolPlugin : Error reading memory
[CCS last error: target is in unexpected RUNNING mode ].
Error: Getting flash ID failed
Error: Failed reading return status.Can not read target memory at location: 0x000000000000000C.
the connection log is here:
ccs_close
serverh = 0
ccs_close; ccs_error = 0
ccs_open
ipaddr = 127.0.0.1
port = 41475
timeout = 15
serverh = 0
ccs_open; ccs_error = 0
ccs_get_connection_count
serverh = 0
count = 1
ccs_get_connection_count; ccs_error = 0
ccs_available_connections
serverh = 0
count = 1
ccs_available_connections; ccs_error = 0
serverh = 0
count = 1
ccs_cc_version
serverh = 0
cc = 0
version.major = 0
version.minor = 0
ccs_cc_version; ccs_error = 0
ccs_set_timeout
serverh = 0
timeout = 15
ccs_set_timeout; ccs_error = 0
serverh = 0
count = 1
ccs_config_server
serverh = 0
cc = 0
server_config = 0
value = 12500
ccs_config_server; ccs_error = 0
ccs_config_chain
serverh = 0
cc = 0
device_list: (size = 1)
device[0]:: core_type=test core(20)
ccs_config_chain; ccs_error = 0
ccs_jtag_lock
serverh = 0
cc = 0
ccs_jtag_lock; ccs_error = 0
JTAG Diagnostics
Starting Power at Probe test ...
Test result: PASSED
Starting IR Scan test ...
Test result: PASSED
Starting Bypass Scan test ...
Test result: PASSED
Starting Arbitrary TAP State Move test ...
Test result: PASSED
Detected JTAG IDCODEs: FAILED
ccs_jtag_unlock
serverh = 0
cc = 0
ccs_jtag_unlock; ccs_error = 0
ccs_config_chain
serverh = 0
cc = 0
device[0]:: core_type=mpc603e(31)
ccs_get_config_chain
serverh = 0
ccs_get_config_chain; ccs_error = 0
serverh = 0
ccs_reset_to_mixed
chain_pos: (size = 1) { 0 (halt) }
ccs_reset_to_mixed; ccs_error = 0; duration=405 ms
ccs_send_message
coreh = [serverh:0;cc_index:0;chain_pos:0]
message = 3
ccs_send_message; ccs_error = 0
ccs_read_register
index = 287
count = 1
size = 4
value: (size = 4)
80811014
ccs_read_register; ccs_error = 0; duration=3 ms
ccs_read_register
index = 2032
count = 1
size = 4
value: (size = 4)
FFF00100
ccs_read_register; ccs_error = 0; duration=1 ms
ccs_read_register
index = 2000
count = 34
size = 4
value: (size = 136)
227E227E 00002328 000082A0 00000000
00F000F0 24BD4295 00002360 00000000
FF800100 FF800000 918A4375 00002358
00000000 00008270 FFFFFFFF F7FFFFFF
24BD4295 3D395017 00000000 B7FFFFFF
00000000 FBD67536 00000000 FFFFFFFF
00000000 00F000F0 FF800000 FF800000
FF800000 FFFFFFFF 00000100 00002328
FFF00100 00000000
ccs_read_register; ccs_error = 0; duration=51 ms
ccs_read_register
index = 8
count = 2
size = 4
value: (size = 8)
00000000 00000000
ccs_read_register; ccs_error = 0; duration=2 ms
ccs_read_register
index = 1
count = 1
size = 4
value: (size = 4)
00000000
ccs_read_mem
addr = [space:0;size:4;address:0xfff00100]
data: (size = 256)
FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
ccs_read_mem; ccs_error = 0; duration=20 ms
ccs_read_mem
addr = [space:0;size:4;address:0xfff00200]
data: (size = 256)
Executing Initialization File: E:\working\new_git\jg-fmss\04_sw\fmss_app\CFG\fmss_init_CORE.tcl
thread break: Stopped, 0x0, 0x0, cpuPowerPCBig, Connected (state, tid, pid, cpu, target)
thread set: Stopped, 0x0, 0x0, cpuPowerPCBig, Connected (state, tid, pid, cpu, target)
ccs_stop_core
ccs_stop_core; ccs_error = 0
ccs_read_register
index = 2032
count = 1
size = 4
radix x
value: (size = 4)
FFF00100
ccs_read_mem
cmdwin::eclipse::config hexprefix 0x
cmdwin::eclipse::config MemIdentifier v
cmdwin::eclipse::config MemWidth 32
cmdwin::eclipse::config MemAccess 32
data: (size = 256)
ccs_read_mem; ccs_error = 0; duration=21 ms
ccs_read_register
index = 2000
count = 34
size = 4
value: (size = 136)
FFF00100 00000000
ccs_read_register
index = 8
count = 2
size = 4
value: (size = 8)
00000000 00000000
ccs_read_register
index = 1
count = 1
size = 4
value: (size = 4)
00000000
cmdwin::eclipse::config MemSwap off
cmdwin::stop
cmdwin::wait 0x200
cmdwin::reset
ccs_reset_to_mixed
ccs_read_register
index = 2032
count = 1
size = 4
value: (size = 4)
FFF00100
ccs_read_register
index = 2032
count = 1
size = 4
value: (size = 4)
FFF00100
cmdwin::mem v:0xFEC00000 = 0x04000080
ccs_write_mem
addr = [space:0;size:4;address:0xfec00000]
data: (size = 4)
04000080
ccs_write_mem; ccs_error = 0; duration=2 ms
cmdwin::mem v:0xFEE00000 16bit = 0x600
ccs_write_mem
addr = [space:0;size:2;address:0xfee00000]
data: (size = 2)
0600
cmdwin::mem v:0xFEC00000 = 0x80000080
ccs_write_mem
data: (size = 4)
80000080
ccs_write_mem; ccs_error = 0; duration=3 ms
cmdwin::mem v:0xFEE00000 = 0x00000000
ccs_write_mem
addr = [space:0;size:4;address:0xfee00000]
data: (size = 4)
00000000
cmdwin::mem v:0xFEC00000 = 0x84000080
ccs_write_mem
data: (size = 4)
84000080
ccs_stop_core
ccs_read_register
index = 2032
count = 1
size = 4
value: (size = 4)
FFF00100
ccs_read_mem
data: (size = 256)
ccs_write_mem
data: (size = 4)
00000000
ccs_write_mem; ccs_error = 0; duration=1 ms
ccs_read_register
index = 2000
count = 34
size = 4
value: (size = 136)
FFF00100 00000000
ccs_read_register
index = 8
count = 2
size = 4
value: (size = 8)
00000000 00000000
ccs_read_register
index = 1
count = 1
size = 4
value: (size = 4)
00000000
cmdwin::mem v:0xFEC00000 = 0x88000080
ccs_write_mem
data: (size = 4)
88000080
ccs_write_mem
data: (size = 4)
00000000
cmdwin::mem v:0xFEC00000 = 0x8C000080
ccs_write_mem
data: (size = 4)
8C000080
ccs_write_mem
data: (size = 4)
00000000
cmdwin::mem v:0xFEC00000 = 0x90000080
ccs_write_mem
data: (size = 4)
90000080
cmdwin::mem v:0xFEE00000 = 0xFF000000
ccs_write_mem
data: (size = 4)
FF000000
cmdwin::mem v:0xFEC00000 = 0x94000080
ccs_write_mem
data: (size = 4)
94000080
ccs_write_mem
data: (size = 4)
00000000
cmdwin::mem v:0xFEC00000 = 0x98000080
ccs_write_mem
data: (size = 4)
98000080
cmdwin::mem v:0xFEE00000 = 0x07000000
ccs_write_mem
data: (size = 4)
07000000
cmdwin::mem v:0xFEC00000 = 0x9C000080
ccs_write_mem
data: (size = 4)
9C000080
ccs_write_mem
data: (size = 4)
00000000
cmdwin::mem v:0xFEC00000 = 0xA0000080
ccs_write_mem
data: (size = 4)
A0000080
cmdwin::mem v:0xFEE00000 = 0x01000032
ccs_write_mem
data: (size = 4)
01000032
cmdwin::mem v:0xFEC00000 = 0xA8000080
ccs_write_mem
data: (size = 4)
A8000080
cmdwin::mem v:0xFEE00000 = 0x981A14FF
ccs_write_mem
data: (size = 4)
981A14FF
cmdwin::mem v:0xFEC00000 = 0xAC000080
ccs_write_mem
data: (size = 4)
AC000080
cmdwin::mem v:0xFEE00000 = 0x0C060C00
ccs_write_mem
data: (size = 4)
0C060C00
cmdwin::mem v:0xFEC00000 = 0x78000080
ccs_write_mem
data: (size = 4)
78000080
cmdwin::mem v:0xFEE00000 = 0x000000FC
ccs_write_mem
data: (size = 4)
000000FC
cmdwin::mem v:0xFEC00000 = 0xB8000080
ccs_write_mem
data: (size = 4)
B8000080
cmdwin::mem v:0xFEE00000 8bit = 0x0
ccs_write_mem
addr = [space:0;size:1;address:0xfee00000]
data: (size = 1)
00
cmdwin::mem v:0xFEC00000 = 0xF4000080
ccs_write_mem
data: (size = 4)
F4000080
cmdwin::mem v:0xFEE00000 = 0xCC044004
ccs_write_mem
data: (size = 4)
CC044004
cmdwin::mem v:0xFEC00000 = 0xF8000080
ccs_write_mem
data: (size = 4)
F8000080
cmdwin::mem v:0xFEE00000 = 0x00004078
ccs_write_mem
data: (size = 4)
00004078
cmdwin::mem v:0xFEC00000 = 0xFC000080
ccs_write_mem
data: (size = 4)
FC000080
cmdwin::mem v:0xFEE00000 = 0x39323235
ccs_write_mem
data: (size = 4)
39323235
cmdwin::mem v:0xFEC00000 = 0xF0000080
ccs_write_mem
data: (size = 4)
F0000080
cmdwin::mem v:0xFEE00000 = 0x0200E875
ccs_write_mem
data: (size = 4)
0200E875
cmdwin::mem v:0xFEC00000 = 0x72000080
ccs_write_mem
data: (size = 4)
72000080
cmdwin::mem v:0xFEE00002 8bit = 0xE0
ccs_write_mem
addr = [space:0;size:1;address:0xfee00002]
data: (size = 1)
E0
cmdwin::mem v:0xFEC00000 = 0x73000080
ccs_write_mem
data: (size = 4)
73000080
cmdwin::mem v:0xFEE00003 8bit = 0xD1
ccs_write_mem
addr = [space:0;size:1;address:0xfee00003]
data: (size = 1)
D1
cmdwin::mem v:0xFEC00000 = 0x74000080
ccs_write_mem
data: (size = 4)
74000080
cmdwin::mem v:0xFEE00002 16bit = 0x00FD
ccs_write_mem
addr = [space:0;size:2;address:0xfee00002]
data: (size = 2)
00FD
cmdwin::mem v:0xFEC00000 = 0x76000080
ccs_write_mem
data: (size = 4)
76000080
cmdwin::mem v:0xFEE00002 8bit = 0x40
ccs_write_mem
data: (size = 1)
40
cmdwin::mem v:0xFEC00000 = 0xA3000080
ccs_write_mem
data: (size = 4)
A3000080
cmdwin::mem v:0xFEE00003 8bit = 0x32
ccs_write_mem
data: (size = 1)
32
cmdwin::reg MSR = 0x00001002
ccs_write_register
index = 2034
count = 1
size = 4
value: (size = 4)
00001002
ccs_write_register; ccs_error = 0; duration=1 ms
ccs_read_register
index = 2034
count = 1
size = 4
value: (size = 4)
00001002
cmdwin::mem v:0x700 = 0x48000000
ccs_write_mem
addr = [space:0;size:4;address:0x00000700]
data: (size = 4)
48000000
cmdwin::reg IABR = 0x702
ccs_write_register
index = 1010
count = 1
size = 4
value: (size = 4)
00000702
ccs_write_register; ccs_error = 0; duration=2 ms
ccs_read_register
index = 1010
count = 1
size = 4
value: (size = 4)
00000702
cmdwin::reg SP = 0xF
ccs_write_register
index = 2001
count = 1
size = 4
value: (size = 4)
0000000F
ccs_write_register; ccs_error = 0; duration=3 ms
ccs_read_register
index = 2001
count = 1
size = 4
value: (size = 4)
0000000F
ccs_read_register
index = 2000
count = 34
size = 4
value: (size = 136)
227E227E 0000000F 000082A0 00000000
FFF00100 00000000
ccs_read_register; ccs_error = 0; duration=52 ms
ccs_read_register
index = 8
count = 2
size = 4
value: (size = 8)
00000000 00000000
ccs_read_register
index = 1
count = 1
size = 4
value: (size = 4)
00000000
ccs_stop_core
ccs_write_mem
addr = [space:0;size:4;address:0x00000000]
data: (size = 640)
00000000 00000000 00000000 00000000
00000000 000000FF 000000FF 00000000
FFFFFFFE 00000000 00000000 00000000
ccs_write_mem; ccs_error = 0; duration=29 ms
ccs_write_mem
addr = [space:0;size:4;address:0x000002b0]
data: (size = 176)
00002AF0 00000000 00002B38 00000000
38380000 00000000 10080000 00000000
10080000 00000000 20080000 00000000
28180000 00000000 10080000 00000000
00002360 000002A4 000002C0 00002618
00000074 000002C8 0000268C 000000C4
000002D0 00002750 000000CC 000002D8
0000281C 000001C4 000002E0 000029E0
00000024 000002E8 00000338 000002F0
00002A04 00002360 00000000 00000000
ccs_write_mem; ccs_error = 0; duration=9 ms
ccs_write_mem
addr = [space:0;size:4;address:0x00002360]
data: (size = 3680)
9421FFD0 7C0802A6 90010034 39610030
4800070D 7C000026 90010010 7C3F0B78
3F80FF80 7F9BE378 3BC00000 3BC00000
48000018 57DA063E 3F2DFFFF 3B397EF8
7F59F1AE 3BDE0001 2E1E0100 4190FFE8
3F40FF80 3F2DFFFF 3B397D90 93590004
3F2DFFFF 3B397D90 83390000 2E190003
419200D0 4090001C 2E190001 41920034
409000A4 2E190000 40900018 480001AC
2E190005 41920124 409001A0 480000D0
3C6DFFFF 38637D90 48000211 480001AC
3BA00000 48000048 3800FFFF 3C6DFFFF
38637D90 9003000C 3C6DFFFF 38637D90
7FA4EB78 48000259 3F2DFFFF 3B397D90
9079000C 3F2DFFFF 3B397D90 8339000C
2E190000 4092001C 3BBD0001 3F2DFFFF
3B397D90 83390008 7E1DC840 4190FFAC
3B400000 3F2DFFFF 3B397D90 93590008
48000138 3C6DFFFF 38637D90 480002C5
3F2DFFFF 3B397D90 9079000C 4800011C
3C6DFFFF 38637D90 48000375 3F4DFFFF
3B5A7D90 907A000C 3B200000 3F4DFFFF
3B5A7D90 933A0008 480000F0 3C6DFFFF
38637D90 389F0008 3CADFFFF 38A57E80
48000501 3F4DFFFF 3B5A7D90 907A000C
833F0008 3F4DFFFF 3B5A7D90 933A0008
3F2DFFFF 3B397E80 3F4DFFFF 3B5A7D90
933A0010 480000A4 3C6DFFFF 38637D90
480002FD 3F2DFFFF 3B397D90 9079000C
3F2DFFFF 3B397D90 8339000C 2E190000
40920044 3C6DFFFF 38637D90 389F0008
3CADFFFF 38A57E80 48000489 833F0008
3F4DFFFF 3B5A7D90 933A0008 3F2DFFFF
3B397E80 3F4DFFFF 3B5A7D90 933A0010
48000038 3B400000 3F2DFFFF 3B397D90
93590008 48000024 3B200200 3F4DFFFF
3B5A7D90 933A000C 3B200000 3F4DFFFF
3B5A7D90 933A0008 3F2000F0 3B3900F0
3F4DFFFF 3B5A7D90 835A0004 933A0400
7FE00008 48000031 4BFFFDE8 7FEAFB78
818A0010 7D8FF120 396A0030 480004E1
81410000 800A0004 7D415378 7C0803A6
4E800020 00000000 9421FFF0 38210010
4E800020 00454E44 9421FFF0 93E1000C
93C10008 83E30004 3BC00000 3C8000F0
388400F0 909F0000 3C8000AA 388400AA
909F1554 3C800055 38840055 909F0AA8
3C800090 38840090 909F1554 801F0000
900D8014 801F0004 900D8010 3C8000F0
388400F0 909F0000 7FC3F378 83E1000C
83C10008 38210010 4E800020 9421FFE0
93E1001C 93C10018 80A30010 5480103A
7FE5002E 3BC00000 3CA00001 38A5F0F0
B0BF0000 3CA00001 38A59090 B0BF0000
A01F0004 2C000000 4182000C 38600000
48000070 3CA00001 38A5F0F0 B0BF0000
380000AA B01F0AAA 38000055 B01F0554
38000080 B01F0AAA 380000AA B01F0AAA
38000055 B01F0554 38000030 B01F0000
A01F0000 B0010008 4800000C A01F0000
B0010008 A0010008 54000630 2C000080
4082FFEC 380000F0 B01F0000 7FC3F378
83E1001C 83C10018 38210020 4E800020
9421FFE0 93E1001C 93C10018 93A10014
93810010 38000000 90010008 3BC00000
3BA00080 3B800080 83E30004 3C80F0F1
3884F0F0 909F0000 3C8000AA 388400AA
3C800080 38840080 909F1554 3C8000AA
388400AA 909F1554 3C800055 38840055
909F0AA8 3C800010 38840010 909F1554
3C800070 38840070 909F1554 5785043E
809F0000 57A0043E 7C800038 7C050040
4082FFEC 3C80F0F1 3884F0F0 909F0000
7FC3F378 83E1001C 83C10018 83A10014
83810010 38210020 4E800020 9421FFC0
7C0802A6 90010044 39610040 48000259
7C3F0B78 7C7B1B78 38000000 901F001C
38000080 B01F000A 38000080 B01F0008
83DB0004 57C00024 901F0018 83BB0010
801B0008 901F0014 801F0014 5400F87E
901F0010 3C600001 3863F0F0 907E0000
3C600001 38639090 907E0000 3C600001
3863F0F0 907E0000 38000098 807F0018
B00300AA 380000F0 807F0018 B0030000
3C600001 3863F0F0 907E0000 3C600001
38639090 907E0000 801F0014 540007FE
2C000000 41820030 801F0014 7C1D0214
901F000C 380000FF 807F000C 98030000
38030001 901F000C 807F0010 38030001
38000000 901F0020 4800007C 57DC0024
380000AA B01C0AAA 38000055 B01C0554
380000A0 B01C0AAA A01D0000 901E0000
A01F000A 54000630 B01F000A A01D0000
54000630 5400043E B01F0008 A01F0008
54000630 B01F0008 A09F0008 807E0000
A01F000A 7C600038 7C040040 4082FFEC
3BDE0004 3BBD0002 807F0020 38030001
901F0020 807F0020 801F0010 7C030040
40800010 801F001C 2C000000 4182FF70
3BDEFFFC 380000F0 901E0000 807F001C
7FEAFB78 396A0040 4800010D 81410000
800A0004 7D415378 7C0803A6 4E800020
9421FFF0 93E1000C 93C10008 3BE00000
83C30004 83E1000C 83C10008 38210010
4E800020 00000000 9421FFF0 7C0802A6
90010014 48000020 80030000 3880FFFF
900D8018 81830004 80630008 7D8903A6
4E800421 806D8018 2C030000 4082FFDC
80010014 7C0803A6 38210010 4E800020
91CBFFB8 91EBFFBC 920BFFC0 922BFFC4
924BFFC8 926BFFCC 928BFFD0 92ABFFD4
92CBFFD8 92EBFFDC 930BFFE0 932BFFE4
934BFFE8 936BFFEC 938BFFF0 93ABFFF4
93CBFFF8 93EBFFFC 4E800020 00000000
81CBFFB8 81EBFFBC 820BFFC0 822BFFC4
824BFFC8 826BFFCC 828BFFD0 82ABFFD4
82CBFFD8 82EBFFDC 830BFFE0 832BFFE4
834BFFE8 836BFFEC 838BFFF0 83ABFFF4
83CBFFF8 83EBFFFC 4E800020 00000000
9421FFF0 7C0802A6 90010014 800D8000
2C00FFFE 40820020 38610008 3881000C
480003C5 80610008 8081000C 48000055
906D8000 80010014 7C0803A6 38210010
90010014 806D8000 2C03FFFE 41820010
48000059 3800FFFE 900D8000 80010014
7C0803A6 38210010 4E800020 00000000
3CAD0000 38A58030 80050008 2C000000
4082001C 90650000 38000001 38600000
90850004 90050008 4E800020 3860FFFF
4E800020 00000000 2C030000 4C820020
1C03000C 3C6D0000 38638030 7C630214
38000000 90030000 90030004 90030008
90010014 4BFFFE25 818D8020 2C0C0000
41820014 7D8903A6 4E800421 38000000
900D8020 818D8024 2C0C0000 41820014
7D8903A6 4E800421 38000000 900D8024
4BFFF9F5 80010014 7C0803A6 38210010
4E800020 4E800020 3CA0FFFF 60A5FFF1
7CA51838 7C651850 7C841A14 7C0004AC
30A50008 3484FFF8 4080FFF4 4C00012C
4E800020 3C600001 38638270 7C636850
4E800020 7C0802A6 4BFFFFED 28030000
41820044 3CA20000 3C820000 38A5AEE0
3884AF18 7CC52050 28060000 41820028
54C6F0BE 7CC903A6 38A5FFFC 84C50004
7CC61A14 80E60000 7CE71A14 90E60000
4200FFEC 7C0803A6 4E800020 7C0802A6
3DA00001 39AD8270 3C400001 384282A0
429F0005 7C8802A6 3C620000 3863AA44
7C632050 28030000 4182000C 7DAD1A14
7C421A14 3C2D0000 3821A0F0 7C0803A6
4E800020 9421FFD0 7C0802A6 90010034
39610030 4BFFFD69 4BFFFF3D 9061001C
3C620000 3BE3AE78 801F0000 2C000000
4082001C 801F0008 2C000000 40820010
801F000C 2C000000 418200D0 807F0004
801F0000 7C001810 7C000110 7C0000D0
90010008 80010008 2C000000 41820028
807F0004 8001001C 7C030214 90010010
807F0000 8001001C 7C030214 9001000C
48000014 801F0000 90010010 801F0004
9001000C 807F000C 801F0008 7C001810
7C000110 7C0000D0 90010008 80010008
2C000000 41820024 807F000C 8001001C
7FA30214 807F0008 8001001C 7C030214
90010014 48000010 83BF0008 801F000C
90010014 80010014 7C1D0050 90010018
7FA3EB78 80810010 80A10018 4800014D
3BFF0010 4BFFFF14 3C620000 3BC3AEC8
801E0000 2C000000 40820010 801E0004
2C000000 41820074 807E0004 801E0000
7C001810 7C000110 7C0000D0 90010008
80010008 2C000000 41820024 807E0004
8001001C 7FA30214 807E0000 8001001C
7C030214 90010014 48000010 83BE0000
801E0004 90010014 80010014 7C1D0050
90010018 7FA3EB78 80810018 48000115
3BDE0008 4BFFFF7C 4BFFFDBD 39610030
4BFFFC1D 80010034 7C0803A6 38210030
4E800020 9421FFF0 93E1000C 7C5F1378
93E40000 3CA20000 38058098 90030000
83E1000C 38210010 4E800020 00000000
7C6E1B78 7C8F2378 7CB02B78 4BFFFD29
4BFFFDBD 9421FFF8 38000000 90010000
3800FFFF 90010004 4BFFFDED 3C620000
3863A368 7C6803A6 4E800021 3CC20000
38C6A0C0 7CC803A6 7DC37378 7DE47B78
7E058378 4E800021 3CC20000 38C6A938
7CC803A6 4E800021 9421FFF0 7C0802A6
2C050000 90010014 93E1000C 7CBF2B78
93C10008 7C7E1B78 4182001C 7C032040
41820014 48000045 7FC3F378 7FE4FB78
4BFFFC99 80010014 83E1000C 83C10008
2C040000 4D820020 7C852378 38800000
48000118 4E800020 7C041840 41800028
3884FFFF 38C3FFFF 38A50001 4800000C
8C040001 9C060001 34A5FFFF 4082FFF4
4E800020 7C842A14 7CC32A14 38A50001
48000010 60000000 8C04FFFF 9C06FFFF
34A5FFFF 4082FFF4 4E800020 00000000
28050020 5487063E 38C3FFFF 41800090
7CC030F8 540007BF 41820014 7CA02850
3400FFFF 9CE60001 4082FFF8 2C070000
4182001C 54E4402E 54E3C00E 54E0801E
7CE42378 7C600378 7C870378 54A0D97F
3866FFFD 4182002C 90E30004 3400FFFF
90E30008 90E3000C 90E30010 90E30014
90E30018 90E3001C 94E30020 4082FFDC
54A0F77F 41820010 3400FFFF 94E30004
4082FFF8 38C30003 54A507BE 2C050000
4D820020 60000000 34A5FFFF 9CE60001
4082FFF8 4E800020 9421FFF0 7C0802A6
90010014 93E1000C 7C7F1B78 4BFFFF35
7FE3FB78 83E1000C 80010014 7C0803A6
38210010 4E800020 00000270 00000000
00000270 00000000 00000280 00000270
00000280 00000270 00000360 000002B0
00000360 000002B0 000031C0 00002360
000031C0 00002360 00000000 00000000
00000000 00000000 000002A0 00000280
000002B0 000002A0 00000000 00000000
000002F0 000002F8 000002FC 00000304
00000308 00000310 00000314 0000031C
00000320 00000328 0000032C 00000334
000002B0 000002B8 00000000 00000000
ccs_write_mem; ccs_error = 0; duration=157 ms
ccs_write_mem
data: (size = 4)
00000000
ccs_write_mem
addr = [space:0;size:4;address:0x00000010]
data: (size = 4)
000031C0
ccs_write_mem
addr = [space:0;size:4;address:0x00000004]
data: (size = 4)
FF800000
ccs_write_mem
addr = [space:0;size:4;address:0x0000000c]
data: (size = 4)
00000000
ccs_write_register
index = 2013
count = 1
size = 4
value: (size = 4)
00000000
ccs_write_register
index = 2032
count = 1
size = 4
value: (size = 4)
00002F00
ccs_read_register
index = 2032
count = 1
size = 4
value: (size = 4)
00002F00
ccs_run_core
ccs_run_core; ccs_error = 0
ccs_read_register
index = 2032
count = 1
size = 4
value: (size = 4)
00000700
ccs_read_mem
data: (size = 4)
15420000
ccs_read_mem; ccs_error = -2147483639; duration=2 ms
Error message: target is in unexpected RUNNING mode
ccs_get_messages
message: (size = 0)
ccs_get_messages; ccs_error = 0
ccs_close
serverh = 0
ccs_core_run_mode
mode = 57996680
ccs_core_run_mode; ccs_error = 7
Error message: Invalid handle
My ini.tcl file is here:
proc init_fmss_cpu {} {
variable SSPR "Standard Special Purpose Registers/"
global IMMRBase
# Set the IMMR so the debugger plugin knows where it is since
# the IMMR itself is a memory mapped register. This does not
# actually write anything to the target, it is simply to inform
# the debugger plugin where the IMMR is
#eppc::setMMRBase $IMMRBase
# relocate internal memory space
# IMMR
#mem [IMMR 0x101A8] = 0x04700000
#set IMMRBase 0x04700000
# Main System Clock Configuration Registers
# Machine Mode Register
#reg ${SSPR}MSR = 0x1002
# PDTEM
#mem [IMMR 0x10054] 8bit = 0x00
# RMR
#mem [IMMR 0x10C94] 16bit = 0x0001
# Setup the chip selects
#mem v:0x00000000 8bit = 0xFF
#CBR refresh.
mem v:0xFEE00000 16bit = 0x600; # bus master and responds to pci memory
mem v:0xFEC00000 = 0x80000080; # starting_address_1
mem v:0xFEE00000 = 0x00000000;
mem v:0xFEC00000 = 0x84000080; # starting_address_2
mem v:0xFEC00000 = 0x88000080; # extended_starting_address_1
mem v:0xFEC00000 = 0x8C000080; # extended_starting_address_2
mem v:0xFEC00000 = 0x90000080; # mem_ending_address_1
mem v:0xFEE00000 = 0xFF000000;
mem v:0xFEC00000 = 0x94000080; # mem_ending_address_2
mem v:0xFEC00000 = 0x98000080; # extended_mem_ending_address_1
mem v:0xFEE00000 = 0x07000000;
mem v:0xFEC00000 = 0x9C000080; # extended_mem_ending_address_2
mem v:0xFEC00000 = 0xA0000080; # bank 0 enable
mem v:0xFEE00000 = 0x01000032;
mem v:0xFEC00000 = 0xA8000080; # PICR_1
#mem v:0xFEE00000 = 0x901A1400; # map B, flash write, processor parked on the data bus
mem v:0xFEE00000 = 0x981A14FF; # map B, flash write, processor parked on the data bus
mem v:0xFEC00000 = 0xAC000080; # PICR_2
mem v:0xFEE00000 = 0x0C060C00; # ROM/Flash WR lockout disable
mem v:0xFEC00000 = 0x78000080; # EUMBBAR
mem v:0xFEE00000 = 0x000000FC; # 0xFC000000
mem v:0xFEC00000 = 0xB8000080; # ECC error
mem v:0xFEE00000 8bit = 0x0;
# ----- Enable memory, 8-bit data path for ROM back 0, enable refresh
# ----- during sleep, RAM type = SDRAM, 11 or 12 row bits
mem v:0xFEC00000 = 0xF4000080; # MCCR_2
mem v:0xFEE00000 = 0xCC044004;
mem v:0xFEC00000 = 0xF8000080; # MCCR_3
mem v:0xFEE00000 = 0x00004078;
mem v:0xFEC00000 = 0xFC000080; # MCCR_4
mem v:0xFEE00000 = 0x39323235;
mem v:0xFEC00000 = 0xF0000080; # MCCR_1
mem v:0xFEE00000 = 0x0200E875;
mem v:0xFEC00000 = 0x72000080; # PMCR_2
mem v:0xFEE00002 8bit = 0xE0; # refresh sdram during sleep
mem v:0xFEC00000 = 0x73000080; # ODCR
mem v:0xFEE00003 8bit = 0xD1;
mem v:0xFEC00000 = 0x74000080; # CDCR
mem v:0xFEE00002 16bit = 0x00FD;
mem v:0xFEC00000 = 0x76000080; # MDCR
mem v:0xFEE00002 8bit = 0x40;
mem v:0xFEC00000 = 0xA3000080; # PGMAX
mem v:0xFEE00003 8bit = 0x32;
reg MSR = 0x00001002; # machine check exceptions enable, Vector=0x000n_nnnn
#;valid opcode at program exception
mem v:0x700 = 0x48000000;
# breakpoint at 0x700 - necessary for flash programmer
reg IABR = 0x702; # 0x700 is addr, 2 is enable
reg SP = 0xF; # prevent stack walk
# perform 8 accesses
# mem v:0x00000000 8bit = 0xFF
proc envsetup {} {
# Environment Setup
radix x
config hexprefix 0x
config MemWidth 32
config MemAccess 32
config MemSwap off
# Main
envsetup
stop
wait 0x200
reset
init_fmss_cpu
タグ(1)
1,553件の閲覧回数
yipingwang
Hello gang liu,
In your CCS log, there is problem to read memory 0x0000000c, probably SDRAM configuration section in CW initialization file is not totally suitable for your custom board.
Would you please do memory test from Tools->Hardware Diagnostics in CodeWarrior IDE?
After filled Configuration panel for your custom board, please do Memory Read/Write test at 0x0000000c.
Yiping
