How to modify my program written for UDP protocol for MPC 860 so that TCP can be implemented?
1,198 次查看
dhirajkumar
I have been using MPC 860 processor in my project. For ethernet communication UDP ptocol has been implemented.
There is requirement to implement TCP/IP protol in my project. What all modification in application software/driver software is required to implement TCP/IP protocol.
Please provide technical note/sample code for TCP/IP implementation in MPC860 processor.
1,127 次查看
Pavel
We do not have standalone program example for the MPC860 TCP/IP.
Usually operating systems supports this protocol.
Look at MQX operating system for the MPC860.
See the following pages:
http://embedded-access.com/products/mqx-rtos/
and
http://embedded-access.com/products/processors/
Pavel Chubakov
