In my project, I use a MPC8313 and Vxworks. I found that the SNAN will change to QNAN automatically. The demo codes show as below:
void testFloatStart()
float Original;
*(uint32*) &Original = 0x7f800001; //SNAN
testFloatNan(Original);
void testFloatNan(float temp)
float Target;
Target = temp;
I hope that the 'Target' is 0x7f800001, but it is 0x7fc00001. I test same codes in other processer, such as A9 or M4. They are ok.
