Flash programming
Flash programming
2,744 次查看
mohsenhaghighat
Hello , I design a board with MPC8308 processor. I can erase the NOR flash with Codewarrior TAP but I can not programming the flash  with Codewarrior TAP. I do not know where is the Problem and i can not find it. Can anybody help me?
I attach a image from codewarrior in programming procedure. when I program the Flash, it does not make any error and this procedure does not finish.
5 回复数
2,580 次查看
mohsenhaghighat
Hello alexander, Thanks . The files are attached.
2,580 次查看
alexander_yakov
Please enable "Verify memory writes" checkbox and check again.
Please submit me the file, referenced in the string below "Use Target Initialization" checkbox
2,580 次查看
mohsenhaghighat
The File that used in target inithialization, is attached.
2,580 次查看
alexander_yakov
2,580 次查看
alexander_yakov
Please also show screenshot from the first page of Flash Programmer, and target initialization file you are using.
