FPGA access using P5040 processor via eLBC
已解决
跳至解决方案
6,225 次查看
hemwant
We are having a customised P5040 board with FPGA device[8bit access] configured at CS2 of eLBC . We are not able to access the registers of FPGA from uboot . On further debugging the issue with oscilloscope, the CS2 is not being asserted when we initiate read/write from uboot.
The dump of complete uboot, eLBC and LAW registers is attached with this post.
标记 (2)
1 解答
5,965 次查看
hemwant
@yipingwangthis issue is resolved , FPGA was configured for little endian whereas processor is accessing in big endian mode.
在原帖中查看解决方案
2 回复数
5,969 次查看
yipingwang
Can you please share your schematic?
5,966 次查看
hemwant
