Hi.
I want to test an application on board MPC8306Som, but I don't want to use any OS, I can compile it in ubtuntu and run in board by the uboot "go" command. However,I want to debug it using CW8.8 ,so i can view the application running details. Is it possible? and how to do it ?
any suggestion is appreciated.
Solved! Go to Solution.
what I could find in u-boot's code is something like this
| /* Initialize the jump table for applications */ |
jumptable_init();
in the arch\powerpc\lib\board.c file.
When you start a standalone application in u-boot it's just jumping to a particular address,
I'm thinking that if you know that address you can just add a breakpoint there, the debugger will
stop and then you can execute step-by-step.
regards,
Catalin
jumptable_init();
regards,
Catalin
