I want to enable logbuffer in u-boot for post result information access in kernel. When i had enabled CONFIG_LOGBUFFER in u-boot for P1020 RDB board,
its stucking after
Flash: 16 MiB
L2: 256 KiB already enabled
NAND: 32 MiB
MMC: FSL_SDHC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: logbuff
Err: logbuff"
Can some body give some pointer where should i look for resolving this.
Shubha
