Access timeout error while programming UBOOT
2,917 次查看
prakharm
We are using T1022 Processor. It is hard coded with 9-E.
Getting access timeout error while programming UBOOT with the help of Lauterbach.
At FLASHFILE.Target command it shows getting FLASHFILE info then access timeout error occurs.
标记 (1)
2,854 次查看
yipingwang
It seems that this is the issue of the tool, please contact https://www.lauterbach.com/
2,897 次查看
rweiss
Please contact Lauterbach support at https://support.lauterbach.com/ to get help on this issue.
