kitpfgui(Version 4.1)
User_mmpf
I am using the kitpfgui(Version 4.1) for the first time. I have not yet connected the target board. For now, I am trying to observe voltage and current values of the PMIC on kit. But whenever I am enabling the target device, the GUI hangs. I have tried the software in Windows 7 and 10. Screenshot attached. Any procedure that I am doing wrong?
Thanks for the help in advance!
guoweisun
Because you don't have EVB or socket connection,so you can't  navigate it!
guoweisun
I remembered that you can try to click 'OTP configuration' then click 'update from socket',you can get your desired sequence.
User_mmpf
I am unable to navigate to any tabs in the GUI. Is it possible to have the previous version for download?
guoweisun
guoweisun
You can connect with EVB then click 'OTP configuration' then give me the picture.
User_mmpf
We do not have a EVB currently. Target board is yet to be fabricated. I am using this kit to get familiar with working of the PMIC and verify sequencing.
guoweisun
You must connect with the EVB then click Enable.
User_mmpf
If only contents of PMIC on kit has to be checked, what should be done?
Currently I want to verify the sequencing alone.
