flexgui x32(x86)
flexgui x32(x86)
2,156 次查看
Ajay2
Recently I got my freedom board. And I would like to use it on x32 machine.
So far I couldn't find flexgui compatible with x32 system. In case x32 flexgui exists, please provide.
2,144 次查看
Ajay2
Hi David,
Hope you are also doing good.
Sorry for not giving you enough information.. I'm using this Evaluation board with FRDM-KL25Z driving it. But unfortunately FlexGUI for Q100 (XS2410 Extreme Switch) only allows to download x64bit application.
So apparently what you assumed should suit me - actually doesn't as I need config and lib files for Q100.
AJ
2,133 次查看
diazmarin09
Once again, thank you for using the NXP communities.
Could you please confirm that you are not able to download and install the file from here?
David
2,149 次查看
diazmarin09
I hope all is great with you.
Could you please share more details about the freedom board that you acquired?
Let’s assume that you need to download the FlexGUI for PF8100/8200/8101/8201/8121 Family.
First, please make sure that you download the Java JRE (Java SE Runtime Environment).
Once the Java JRE in installed, run GUI using 'flexgui-app-pf8xxx.bat' file located in 'bin' folder.
I hope this information helps.
David
