I've noticed that whenever I select "DEBUG MODE EXIT" on the FS26 and burn the S32K3X4EVB-T172 using MicroUSB, this message " CONNECTION CLOSED BY GDB SERVER " appears the next time I do so.
However, if I don't use the "DEBUG MODE EXIT" option for FS26, I can repeatedly flash the program without encountering the "CONNECTION CLOSED BY GDB SERVER" error. Why is that?
