VR5510 FSM_STATES always is ASSERT_FS0B
1,888 次查看
GuoGuo
     When we read the VR5510 chip state in some boaed use VR5510 ,the FSM_STATES is ASSERT_FS0B,So it can't goto standby mode,but other normal chip read resault is  NORMAL_FS,Which can cause that? Thank you!
标记 (1)
1,877 次查看
guoweisun
You can try to do cross test for example use the bad board's SBC solder into good board,or use the good board's SBC solder into bad board.
1,878 次查看
guoweisun
