Use FRDM-KV31F with FRDM33771BSPIEVB
1,182件の閲覧回数
ghamblin
Hi, I'm trying to use the FRDMKV31F with the FRDM33771B evaluation board. Because at the time could not find any available FRDMKL25Z boards. The KV31F is listed as compatible with the 33771B evaluation board. The datasheet shows the jumpers that need to be set up, and I have done that. The problem I have is that the demo GUI only gives the option of using the KL25Z. Does anyone here know how I can make this work or where I can get the firmware to make it work?
Thanks in advance,
Glenn
1,161件の閲覧回数
diazmarin09
Hello Glenn,
I hope all is great with you. Thank you for using the NXP communities.
As previously discussed, the FRDM-KV31F is incompatible with the GUI unless the software is modified.
I hope this information helps.
David
