UJA1169A Restoring factory preset values fail
663 次查看
realin
#hu
0x74=0x08,0x73=0x08,UJA1169A Restoring factory preset values fail
4 回复数
656 次查看
realin
芯片第一次MTP重新编程,将0X73=0X08,0X74=0X08,ok之后,欲恢复出厂设置,将RESET=0,CANL=0,CANH=VBAT,VBAT重新上电,芯片不能恢复出厂设置,请帮忙分析一下原因
635 次查看
JozefKozon
Dear Realin,
please state what Evaluation board you are using. Please state a full product number or a link to the evaluation board. If you have your own design please share the schematic with voltage levels and part values.
 With Best Regards,
Jozef
622 次查看
realin
使用的EVB单板为UJA1169AF3_EVB
601 次查看
JozefKozon
Dear Realin,
please make sure the BAT pin is unsupplied when you are trying to factory reset the UJA1169A.
Please check and share the content of the WRCNTS bit in the MTPNV status register. To confirm that the SBC registers were not restored.
With Best Regards,
Jozef
