Qi charger controller NXP 5P101
2,026 次查看
MattFix
Hey there.
The Qi Charger from my prestige 9000 broke. After some testing I found shorted caps around this IC while its getting relatively hot.
The Problem is I couldnt identify it. Google doesnt know it. But it says NXP 5P101.
I wonder if there is a compatible IC from NXP so I can fix my charger.
Matt
1 回复
2,013 次查看
ErikaC
Yes, this is an NXP part, but since this is a customer special part due to contractual reasons, I am not allowed to provide any information about customer-specific parts.
Customer specific device was made by NXP based on a specific contract for the specific company, only they can obtain the information, all information is confidential.
I cannot give you a recommendation because I don't know the design of the charger, the only thing I can recommend you is to contact whoever designed the charger so they can give you some recommendations.
Hope this helps.
Regards.
