Power up Ramp
Power up Ramp
3,601件の閲覧回数
bettinawyss
I would like to use PF8200 together with PolarFire FPGA in a project. However, I noticed that the power ramp up times are slightly outside the specifications of PolarFire (200us). Is there a way to somehow get longer ramp up times?
Thank you in advance
Betty
3 返答(返信)
3,589件の閲覧回数
bettinawyss
Yes exactly. E.g: the start up ramp of the voltage regulator output should take at least 200us to go from 0 to 1V.
3,584件の閲覧回数
guoweisun
For the slew rate time which can't modify for the output regulators.
3,594件の閲覧回数
guoweisun
Do you mean the start up time?do you need longer than 200us of PMIC?
