Power supply sequence for NVCC_XXXX
1,729 次查看
yuji_fuseki
Do we have any requirement for power supply sequence of NVCC_XXXX if supplied voltage is provided from external power source?
Yuji
标记 (1)
1,625 次查看
yuji_fuseki
Hi, Igor
Thanks.
i understood.
yuji
1,625 次查看
igorpadykov
Hi Yuji
no special requirements, just follow power-up sequence defined in datasheet.
