PF8100EPES&EQES OTP program issues
1,797 次查看
Sam1978
hi folks:
 I applied PF8100EPES and PF8100EQES for imx8qm6avufabb,also i setup a configure script for OTP burnning as per otp form in directory flexGUI,i tried to run this script to burn otp fuse with KITPF8200FRDMPGM tools,but it always restore to default value after re-power on ,anybody can give me your solutions if you met this issue ,thanks!
 best reguards
 Sam
disconnect usb cable,and power up again:
run read otp script,showed below:
1,787 次查看
guoweisun
Had already replied by case.
