PF8100 FOR LS1046A
2,492件の閲覧回数
Ellu24
Can I use MC33PF8100EPES for LS1046a , as this is a programmable one. Is it possible for me to use MC33PF8100EPES for LS1046 if I use TBBEN for programming desired voltages?
Thanks in Advance
2,479件の閲覧回数
guoweisun
In the datasheet of PF8100,we  recommend MC33PF8100EAES for LS1046A not others version.
But I am not the expert of LS1046A and only focus on PMIC ,for double check you can submit ticket for this MPU questions.
Home (nxp.com)
タグ(1)
3 返答(返信)
2,483件の閲覧回数
Ellu24
Thanks for the reply. So is it possible to use MC33PF8100EPES for LS1046A without TBB mode?
2,480件の閲覧回数
guoweisun
Home (nxp.com)
タグ(1)
2,485件の閲覧回数
guoweisun
That's not easy for use the TBB mode, because you should other MCU to program PF8100 into TBB mode and related registers, each time power on reset you need do these same steps.
