PF8100 FOR LS1046A
PF8100 FOR LS1046A
Ellu24
Can I use MC33PF8100EPES for LS1046a , as this is a programmable one. Is it possible for me to use MC33PF8100EPES for LS1046 if I use TBBEN for programming desired voltages?
Thanks in Advance
guoweisun
In the datasheet of PF8100,we  recommend MC33PF8100EAES for LS1046A not others version.
But I am not the expert of LS1046A and only focus on PMIC ,for double check you can submit ticket for this MPU questions.
Home (nxp.com)
Ellu24
Thanks for the reply. So is it possible to use MC33PF8100EPES for LS1046A without TBB mode?
guoweisun
Home (nxp.com)
guoweisun
That's not easy for use the TBB mode, because you should other MCU to program PF8100 into TBB mode and related registers, each time power on reset you need do these same steps.
