PCA9617 Iol graph when Vol is 5V
1,429 次查看
yuji0935
Do you have graphs showing the 5V Vol data from Figure 10 and Figure 11?yuji0935_0-1737420135188.png
1,408 次查看
yuji0935
I will use Vcc5V. The pull-up resistor is 1.5kΩ. I will use it at about 3mA. In that case, how many volts will Vol drop to?
1,404 次查看
guoweisun
No more data for reference according your test condition,suggest you do simulation by using IBIS model:
PCA9617A | NXP Semiconductors
1,413 次查看
guoweisun
Hi yuji0935
Unfortunately there is no such parameter for reference here.
