PCA9460B BUCK1 CPU
PCA9460B BUCK1 CPU
Graph0115
I was reviewing the PDF for the design of the I.MX8ULP EVK for 15*15mm I.MX8ULP and one thing didn't quite click, i saw that there were a bunch of usages of  BUCK1_CPU_1V8 however i only saw BUCK1_1V8 being defined, defined as in power injected through by the PMIC or used a pin to output to the aforementioned component
I would like to confirm whether BUCK1_1V8 and BUCK1_CPU_1V8 are the same? or they are a seperate circuit that crossed over to another PDF since i have used the find function and there are only usages and notes about it but no power injections or outputs to it
Graph0115
Don't worry guys, i found it on the next page.. why wouldn't they put a page ref for that one
%3CLINGO-SUB%20id%3D%22lingo-sub-2318323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPCA9460B%20BUCK1%20CPU%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20was%20reviewing%20the%20PDF%20for%20the%20design%20of%20the%20I.MX8ULP%20EVK%20for%2015*15mm%20I.MX8ULP%20and%20one%20thing%20didn't%20quite%20click%2C%20i%20saw%20that%20there%20were%20a%20bunch%20of%20usages%20of%26nbsp%3B%20BUCK1_CPU_1V8%20however%20i%20only%20saw%20BUCK1_1V8%20being%20defined%2C%20defined%20as%20in%20power%20injected%20through%20by%20the%20PMIC%20or%20used%20a%20pin%20to%20output%20to%20the%20aforementioned%20component%3CBR%20%2F%3EI%20would%20like%20to%20confirm%20whether%20BUCK1_1V8%20and%20BUCK1_CPU_1V8%20are%20the%20same%3F%20or%20they%20are%20a%20seperate%20circuit%20that%20crossed%20over%20to%20another%20PDF%20since%20i%20have%20used%20the%20find%20function%20and%20there%20are%20only%20usages%20and%20notes%20about%20it%20but%20no%20power%20injections%20or%20outputs%20to%20it%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2318323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EPMIC%20for%20i.MX%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2318324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3Efound%20it%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2318324%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDon't%20worry%20guys%2C%20i%20found%20it%20on%20the%20next%20page..%20why%20wouldn't%20they%20put%20a%20page%20ref%20for%20that%20one%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
