PCA9420 Charger
PCA9420 Charger
teruteru5678
I am developing a wearable device using the PC9420 and RT6 series.
It runs on a battery, so I need to charge it.
Question
1.After switching from MODE0 to standby with PWR_DN_EN=1, is it possible to charge it by inputting 5V to VIN?
2.After switching to standby with PWR_DN_EN=1, I would like to turn on the LED when charging is complete. Is this possible if I use the INT pin?
I would like the LED to light only when charging is complete.
Thank you in advance.
guoweisun
Hi Teruteru
Exactly we often recommend to use ship mode getting the charger active.
condition:
SHIP_EN=1 AND
VIN present AND
ON=1 AND
OPERATION_SEL_FROM_SHIPMODE=1
guoweisun
Hi teruteru5678
Question
[gw]do you mean enable charger function under power down status?
Thanks!
teruteru5678
Thank you for your reply.
Yes, that's right.
I would like to be able to charge the device even when it's turned off.
I understand that the device is turned off when it detects that it's ON and sets PWR_DN_EN=1,
but is this done incorrectly?
guoweisun
I will test it next this function and give you feedback ASAP!
teruteru5678
Thank you.
I checked the data sheet and understood that it can be charged using ShipMode.
Do you generally use ShipMode to turn the power off (to save power)?
If so, I will use ShipMode.
guoweisun
Hi Teruteru
condition:
SHIP_EN=1 AND
VIN present AND
ON=1 AND
%3CLINGO-SUB%20id%3D%22lingo-sub-2000523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPCA9420%20Charger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2000523%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20developing%20a%20wearable%20device%20using%20the%20PC9420%20and%20RT6%20series.%3CBR%20%2F%3EIt%20runs%20on%20a%20battery%2C%20so%20I%20need%20to%20charge%20it.%3C%2FP%3E%3CP%3EQuestion%3CBR%20%2F%3E1.After%20switching%20from%20MODE0%20to%20standby%20with%20PWR_DN_EN%3D1%2C%20is%20it%20possible%20to%20charge%20it%20by%20inputting%205V%20to%20VIN%3F%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E2.After%20switching%20to%20standby%20with%20PWR_DN_EN%3D1%2C%20I%20would%20like%20to%20turn%20on%20the%20LED%20when%20charging%20is%20complete.%20Is%20this%20possible%20if%20I%20use%20the%20INT%20pin%3F%3CBR%20%2F%3EI%20would%20like%20the%20LED%20to%20light%20only%20when%20charging%20is%20complete.%3CBR%20%2F%3EThank%20you%20in%20advance.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2000815%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PCA9420%20Charger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2000815%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%20class%3D%22lia-message-author-avatar%20lia-component-author-avatar%20lia-component-message-view-widget-author-avatar%22%3E%0A%3CDIV%20class%3D%22UserAvatar%20lia-user-avatar%20lia-component-common-widget-user-avatar%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22UserAvatar%20lia-user-avatar%20lia-component-common-widget-user-avatar%22%3EHi%20Teruteru%3C%2FDIV%3E%0A%3CDIV%20class%3D%22UserAvatar%20lia-user-avatar%20lia-component-common-widget-user-avatar%22%3EExactly%20we%20often%20recommend%20to%20use%20ship%20mode%20getting%20the%20charger%20active.%3C%2FDIV%3E%0A%3CDIV%20class%3D%22UserAvatar%20lia-user-avatar%20lia-component-common-widget-user-avatar%22%3Econdition%3A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22UserAvatar%20lia-user-avatar%20lia-component-common-widget-user-avatar%22%3ESHIP_EN%3D1%20AND%3CBR%20%2F%3EVIN%20present%20AND%3CBR%20%2F%3EON%3D1%20AND%3CBR%20%2F%3EOPERATION_SEL_FROM_SHIPMODE%3D1%3C%2FDIV%3E%0A%3CDIV%20class%3D%22UserAvatar%20lia-user-avatar%20lia-component-common-widget-user-avatar%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lia-message-author-with-avatar%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lia-message-author-with-avatar%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lia-message-author-with-avatar%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lia-message-author-with-avatar%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lia-message-author-with-avatar%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lia-message-author-with-avatar%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22lia-message-author-with-avatar%22%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2000806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PCA9420%20Charger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2000806%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you.%3CBR%20%2F%3E%3CBR%20%2F%3EI%20checked%20the%20data%20sheet%20and%20understood%20that%20it%20can%20be%20charged%20using%20ShipMode.%3CBR%20%2F%3E%3CBR%20%2F%3EDo%20you%20generally%20use%20ShipMode%20to%20turn%20the%20power%20off%20(to%20save%20power)%3F%3CBR%20%2F%3E%3CBR%20%2F%3EIf%20so%2C%20I%20will%20use%20ShipMode.%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2000687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PCA9420%20Charger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2000687%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EI%20will%20test%20it%20next%20this%20function%20and%20give%20you%20feedback%20ASAP!%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2000652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PCA9420%20Charger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2000652%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you%20for%20your%20reply.%3CBR%20%2F%3E%3CBR%20%2F%3EYes%2C%20that's%20right.%3CBR%20%2F%3E%3CBR%20%2F%3EI%20would%20like%20to%20be%20able%20to%20charge%20the%20device%20even%20when%20it's%20turned%20off.%3CBR%20%2F%3E%3CBR%20%2F%3EI%20understand%20that%20the%20device%20is%20turned%20off%20when%20it%20detects%20that%20it's%20ON%20and%20sets%20PWR_DN_EN%3D1%2C%3CBR%20%2F%3E%3CBR%20%2F%3Ebut%20is%20this%20done%20incorrectly%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2000624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20PCA9420%20Charger%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2000624%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CSPAN%3Eteruteru5678%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EQuestion%3CBR%20%2F%3E1.After%20switching%20from%20MODE0%20to%20standby%20with%20PWR_DN_EN%3D1%2C%20is%20it%20possible%20to%20charge%20it%20by%20inputting%205V%20to%20VIN%3F%3C%2FP%3E%0A%3CP%3E%5Bgw%5Ddo%20you%20mean%20enable%20charger%20function%20under%20power%20down%20status%3F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CBR%20%2F%3EThanks!%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%3C%2FLINGO-BODY%3E
