Overcurrent protection in NX20P5090
2,568 次查看
Danz1
Maximum continuous output current for NX20P5090 is 5A. Is there any overcurrent protection feature for this load switch? What happens if a short-circuit occur at the output load? Thanks.
标记 (1)
2,557 次查看
guoweisun
There is no over current protection,it used in USB PD terminal if happened on short event,the PD terminal will prevent.
2,544 次查看
Danz1
Thanks, Guowei.
2,558 次查看
guoweisun
