MPF5020 Part Number
MPF5020 Part Number
hyoungkikim
Hi  experts
i will design  a new board with IMX6SX   and want to use MPF5020 PMIC
on NXP site  a part name is MPF5020CM....,  but on mouse.com  a available part is MPF5020AVNA0ES
is it a old revision ?   what is the difference ?
i  couldn't find  a MPF5020AVNA0ES datasheet
any infomation will be of great help
thank you
guoweisun
Please note that MPF5020AVNA0ES is no recommend for new design!
You can select the PF0200/PF3000!
hyoungkikim
Hi guoweisun
AN12992   1 PMICs and i.MX6 processor matrix table
PF5020 is avaiable with I.MX6X
and if i can buy MPF5020CMMA0ES, but i can't find one from  mouser.com, digikey.com
so..if two parts are pin-compatible , i will test a board with MPF5020AVNA0ES and later change to MPF5020CMMA0ES, that is why i try to find a datasheet
about PF3000 , i can't find any stock neither  and looks liket that it is a bit expensive
guoweisun
Yes, MPF5020AVNA0ES and MPF5020CMMA0ES are pin-compatible.
