KITPF09FRDMPGM – Wrong Board Included?
199 次查看
d_j
I ordered a KITPF09FRDMPGM. The delivery included the KITPF09FRDMPGM and a separate FRDM-KL25Z board.
However, I don't think the two boards are compatible, or at least I don't see how they are supposed to be connected. For example, the J21 header on the FRDM-KL25Z is mechanically in the way.
In addition, the pin headers required to plug the KITPF09FRDMPGM into the FRDM-KL25Z are missing.
Could somone please confirm whether the correct board was included with the kit? Shouldn't it look similar to the board supplied with the KITPF7100FRDMPGM?
5 回复数
138 次查看
ErikaC
The board included with the KITPF09FRDMPGM is the correct board. The KITPF09FRDMPGM and the FRDM-KL25Z are supplied as separate boards and are compatible when assembled as intended.
The required pin headers are not included pre-installed and must be purchased separately and soldered onto the boards. Once the appropriate headers are installed, the boards can be connected correctly.
I have tested the KITPF09FRDMPGM board without any problems, so the board itself is correct and functional.
Hope this helps!
125 次查看
d_j
I have now soldered on the headers. However, nothing happens when I try to connect the kit using the NXP_GUI. I also found an old kit for the PF8100 with an older FRDM-KL25Z; that one is detected. What could be wrong?
100 次查看
d_j
Perhaps I bricked the firmware. Can you tell me if this the correct firmware: OpenSDA/PEMicro/2016-02-08/MSD-DEBUG-FRDM-KL25Z_Pemicro_v118.SDA at master · savoca/OpenSDA · GitHub
...or can you give me the link to the correct firmware?
133 次查看
d_j
I’m still surprised that it’s supposed to fit. The outline is different, and connector J21 interferes with the board. Should I desolder it?
Shouldn't the controller board look more like this?
128 次查看
d_j
Okay, I’ve thought about it again. J21 is probably just a jumper and won't interfere with the top board if the pin headers are installed. I'll give it a try.
%3CLINGO-SUB%20id%3D%22lingo-sub-2418143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKITPF09FRDMPGM%20%E2%80%93%20%E6%98%AF%E5%90%A6%E5%8C%85%E5%90%AB%E9%94%99%E8%AF%AF%E7%9A%84%E6%9D%BF%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2418143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CDIV%3E%3CP%3E%E6%88%91%E8%AE%A2%E8%B4%AD%E4%BA%86%E4%B8%80%E5%8F%B0%20KITPF09FRDMPGM%E3%80%82%E4%BA%A4%E4%BB%98%E5%86%85%E5%AE%B9%E5%8C%85%E6%8B%AC%20KITPF09FRDMPGM%20%E5%92%8C%E4%B8%80%E5%9D%97%E5%8D%95%E7%8B%AC%E7%9A%84%20FRDM-KL25Z%20%E6%9D%BF%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%E8%BF%99%E4%B8%A4%E4%B8%AA%E6%9D%BF%E4%B8%8D%E5%85%BC%E5%AE%B9%EF%BC%8C%E6%88%96%E8%80%85%E8%87%B3%E5%B0%91%E6%88%91%E7%9C%8B%E4%B8%8D%E5%87%BA%E5%AE%83%E4%BB%AC%E5%BA%94%E8%AF%A5%E5%A6%82%E4%BD%95%E8%BF%9E%E6%8E%A5%E3%80%82%E4%BE%8B%E5%A6%82%EF%BC%8CFRDM-KL25Z%20%E4%B8%8A%E7%9A%84%20J21%20%E6%8E%A5%E5%A4%B4%E5%9C%A8%E6%9C%BA%E6%A2%B0%E4%B8%8A%E4%BC%9A%E5%A6%A8%E7%A2%8D%E6%93%8D%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%B0%86%20KITPF09FRDMPGM%20%E6%8F%92%E5%85%A5%20FRDM-KL25Z%20%E6%89%80%E9%9C%80%E7%9A%84%E9%92%88%E8%84%9A%E6%8E%A5%E5%A4%B4%E4%B9%9F%E7%BC%BA%E5%A4%B1%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E9%97%AE%E6%9C%89%E4%BA%BA%E8%83%BD%E7%A1%AE%E8%AE%A4%E4%B8%80%E4%B8%8B%E5%A5%97%E4%BB%B6%E9%87%8C%E6%98%AF%E5%90%A6%E5%8C%85%E5%90%AB%E4%BA%86%E6%AD%A3%E7%A1%AE%E7%9A%84%E6%9D%BF%E5%90%97%EF%BC%9F%E5%AE%83%E7%9C%8B%E8%B5%B7%E6%9D%A5%E4%B8%8D%E5%BA%94%E8%AF%A5%E5%92%8C%20KITPF7100FRDMPGM%20%E9%99%84%E5%B8%A6%E7%9A%84%E6%9D%BF%E7%9B%B8%E4%BC%BC%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2418143%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3Ei.MX%20%E7%9A%84%20PMIC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2418522%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KITPF09FRDMPGM%20%E2%80%93%20Wrong%20Board%20Included%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2418522%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%20class%3D%22wnfdntw%20_1ibi0s3fd%20_1ibi0s3ce%20_1ibi0s3eg%22%20data-pm-slice%3D%221%201%20%5B%5D%22%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%20class%3D%22wnfdntw%20_1ibi0s3fd%20_1ibi0s3ce%20_1ibi0s3eg%22%3EKITPF09FRDMPGM%20%E5%A5%97%E4%BB%B6%E4%B8%AD%E5%8C%85%E5%90%AB%E7%9A%84%E6%9D%BF%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E6%9D%BF%E3%80%82KITPF09FRDMPGM%20%E5%92%8C%20FRDM-KL25Z%20%E6%98%AF%E4%BD%9C%E4%B8%BA%E5%8D%95%E7%8B%AC%E7%9A%84%E6%9D%BF%E6%8F%90%E4%BE%9B%E7%9A%84%EF%BC%8C%E5%B9%B6%E4%B8%94%E6%8C%89%E9%A2%84%E6%9C%9F%E7%BB%84%E8%A3%85%E6%97%B6%E6%98%AF%E5%85%BC%E5%AE%B9%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%20class%3D%22wnfdntw%20_1ibi0s3fd%20_1ibi0s3ce%20_1ibi0s3eg%22%3E%E6%89%80%E9%9C%80%E7%9A%84%E9%92%88%E8%84%9A%E6%8E%92%E9%92%88%E6%9C%AA%E9%A2%84%E5%85%88%E5%AE%89%E8%A3%85%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%8D%95%E7%8B%AC%E8%B4%AD%E4%B9%B0%E5%B9%B6%E7%84%8A%E6%8E%A5%E5%9C%A8%E6%9D%BF%E4%B8%8A%E3%80%82%E5%AE%89%E8%A3%85%E5%A5%BD%E5%90%88%E9%80%82%E7%9A%84%E6%8E%A5%E5%A4%B4%E5%90%8E%EF%BC%8C%E5%B0%B1%E5%8F%AF%E4%BB%A5%E6%AD%A3%E7%A1%AE%E8%BF%9E%E6%8E%A5%E6%9D%BF%E4%BA%86%E3%80%82%3C%2FP%3E%0A%3CP%20class%3D%22wnfdntw%20_1ibi0s3fd%20_1ibi0s3ce%20_1ibi0s3eg%22%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%B5%8B%E8%AF%95%E8%BF%87%20KITPF09FRDMPGM%20%E6%9D%BF%EF%BC%8C%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E9%97%AE%E9%A2%98%EF%BC%8C%E6%89%80%E4%BB%A5%E6%9D%BF%E5%AD%90%E6%9C%AC%E8%BA%AB%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%EF%BC%8C%E5%8A%9F%E8%83%BD%E4%B9%9F%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%0A%3CP%20class%3D%22wnfdntw%20_1ibi0s3fd%20_1ibi0s3ce%20_1ibi0s3eg%22%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%88%B0%E4%BD%A0%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2418772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KITPF09FRDMPGM%20%E2%80%93%20Wrong%20Board%20Included%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2418772%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E6%8A%8A%E6%8E%92%E9%92%88%E7%84%8A%E6%8E%A5%E5%A5%BD%E4%BA%86%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%20NXP_GUI%20%E8%BF%9E%E6%8E%A5%E8%AF%A5%E5%A5%97%E4%BB%B6%E6%97%B6%EF%BC%8C%E6%B2%A1%E6%9C%89%E4%BB%BB%E4%BD%95%E5%8F%8D%E5%BA%94%E3%80%82%E6%88%91%E8%BF%98%E6%89%BE%E5%88%B0%E4%BA%86%E4%B8%80%E4%B8%AA%E9%80%82%E7%94%A8%E4%BA%8E%20PF8100%20%E7%9A%84%E6%97%A7%E5%A5%97%E4%BB%B6%EF%BC%8C%E5%85%B6%E4%B8%AD%E5%8C%85%E5%90%AB%E4%B8%80%E4%B8%AA%E8%BE%83%E6%97%A7%E7%9A%84%20FRDM-KL25Z%EF%BC%9B%E8%AF%A5%E5%A5%97%E4%BB%B6%E5%B7%B2%E8%A2%AB%E6%A3%80%E6%B5%8B%E5%88%B0%E3%80%82%E5%88%B0%E5%BA%95%E5%87%BA%E4%BA%86%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2418667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KITPF09FRDMPGM%20%E2%80%93%20Wrong%20Board%20Included%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2418667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E5%90%A7%EF%BC%8C%E6%88%91%E5%8F%88%E4%BB%94%E7%BB%86%E8%80%83%E8%99%91%E4%BA%86%E4%B8%80%E4%B8%8B%E3%80%82J21%20%E5%8F%AF%E8%83%BD%E5%8F%AA%E6%98%AF%E4%B8%80%E4%B8%AA%E8%B7%B3%E7%BA%BF%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%AE%89%E8%A3%85%E4%BA%86%E9%92%88%E5%BA%A7%EF%BC%8C%E5%B0%B1%E4%B8%8D%E4%BC%9A%E5%B9%B2%E6%89%B0%E9%A1%B6%E6%9D%BF%E3%80%82%E6%88%91%E8%AF%95%E8%AF%95%E7%9C%8B%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2418633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20KITPF09FRDMPGM%20%E2%80%93%20Wrong%20Board%20Included%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2418633%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BB%8D%E7%84%B6%E5%BE%88%E6%83%8A%E8%AE%B6%E5%AE%83%E5%B1%85%E7%84%B6%E8%83%BD%E5%90%88%E8%BA%AB%E3%80%82%E5%A4%96%E5%BD%A2%E5%B0%BA%E5%AF%B8%E4%B8%8D%E5%90%8C%EF%BC%8C%E8%80%8C%E4%B8%94%E8%BF%9E%E6%8E%A5%E5%99%A8J21%E4%BC%9A%E5%B9%B2%E6%89%B0%E7%94%B5%E8%B7%AF%E6%9D%BF%E3%80%82%E6%88%91%E5%BA%94%E8%AF%A5%E6%8A%8A%E5%AE%83%E6%8B%86%E7%84%8A%E4%B8%8B%E6%9D%A5%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22KITPF09FRDMPGM.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KITPF09FRDMPGM.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397315i205E9FC6E4E7F631%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22KITPF09FRDMPGM.png%22%20alt%3D%22KITPF09FRDMPGM.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%8E%A7%E5%88%B6%E5%99%A8%E6%9D%BF%E4%B8%8D%E5%BA%94%E8%AF%A5%E6%9B%B4%E5%83%8F%E8%BF%99%E6%A0%B7%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22KITPF7100FRDMPGM-ASSEMBLY.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22KITPF7100FRDMPGM-ASSEMBLY.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F397314i972D3C2024496862%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22KITPF7100FRDMPGM-ASSEMBLY.png%22%20alt%3D%22KITPF7100FRDMPGM-ASSEMBLY.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E
