Issue with MC34VR5100A1EP chip
8,896 次查看
minalnemade
       We have build custom board with LS1012A and PMIC chip MC34VR5100A1EP. We are facing issue of VSNVS output from PMIC chip. We are providing 3.3V input to PMIC chip but we are not getting VSNVS output inspite of Vin voltage > 3.1V. We have connected VSNVS output to EN pin of PMIC chip. As VSNVS output is missing PMIC chip is not getting enabled and hence it is not generating any output voltages. As per data-sheet of PMIC chip VSNVS output can not be disabled and is generated after Vin voltage > 3.1V (UVDET). Inspite of this condition being met we observed that VSNVS output is not generated by PMIC chip. We are not using coin cell battery input and hence LICELL input of PMIC chip is bypassed to ground through 0.1uf capacitor. All connections of PMIC chip are as per the reference design of LS1012AFRDM. Please let's know what could be the issue.
regards
Minal
8,689 次查看
guoweisun
Can you double check your VSNVS connection in your system except VSNVS connect with EN?
It seems that VSNVS has current limit.
7 回复数
8,689 次查看
guoweisun
Please note the output current of VSNVS(1mA) and you'd better give us your schematic.
8,689 次查看
minalnemade
Hi Jive,
Please find attached schematics.
Minal
8,689 次查看
guoweisun
Disconnect VSNVS and EN,you can use external signal to control EN then to check this issue.
8,689 次查看
minalnemade
Hi Jive,
We have directly connected 3.3V through 4.7K resistor but we observed
that output voltages randomly comes up and then goes back down.
Please guide.
Thanks & Regards
Minal
8,689 次查看
guoweisun
Do you mean that disconnect with EN and VSNVS then supply EN with external 3.3V with 4.7K resistor?
Do you monitor the VSNVS value when you do above operation?
8,689 次查看
minalnemade
yes .. we have disconnected EN and VSNVS then supply EN with external
3.3V with 4.7K resistor.
We observed VSNVS to be randomly increasing and going down. It goes max to
2.3V
Thanks & Regards
Minal
8,690 次查看
guoweisun
