FS2620 functional safety
2,581 次查看
Kojimaa
Hi experts,
  I have two questions for you:
  1:How to release FS0B again after focing FS0B assertion(FS0B_REQ = 1)?
  2:If the configuration parameters do not change, can I skip configuring the INIT_FS registers after focing RSTB assertion(RSTB_REQ = 1)?
2,565 次查看
guoweisun
1: You can set SBC into normal mode.
2:No .
2,566 次查看
guoweisun
2:No .
