FS26 non-AUTOSAR driver - How To?
4,361 次查看
julian-quindt
Dear,
we are using the FS26 in a design around a TMS570 MCU. I already have access to the respective FS26 driver (FS26_4.4_1.0.0_RTM_D2209). As far as I understand, this driver can support both, AUTOSAR and non-AUTOSAR implementations (please confirm). We do not use AUTOSAR.
Since we do not use the S32DS, I was wondering how I am supposed to configure the driver for this use case. A quick walkthrough or pointers to relevant documentation would be appreciated.
Further, I understand the FS26 safety manual to cover only S32K type MCUs (please confirm) and that I would have to qualify my use of the driver myself. Is this the case?
Thank you.
4,327 次查看
JozefKozon
Dear Julian,
this would be a question for an MCU team. I do not support MCUs, but analog devices and sensors. The PMICs and SBCs included. Could you please create a new case here? In the Subject and/or in the Description please mention the S32K3 and TMS570 MCUs and the MCU support team will help you. Please also check following links. It might be interesting for you.
https://www.nxp.com/docs/en/application-note/AN13431.pdf
https://www.nxp.com/products/power-management/pmics-and-sbcs/pmics-and-sbcs-for-multi-vendor-process...
https://www.nxp.com/products/power-management/pmics-and-sbcs:POWR_MAN_USER_INTERFACE
With Best Regards,
Jozef
5 回复数
3,414 次查看
Birsen
Can you share FS26 driver (FS26_4.4_1.0.0_RTM_D2209) ?
4,344 次查看
JozefKozon
Dear Julian,
yes, the FS26_4.4_1.0.0_RTM_D2209 supports both autosar and non-autosar. Please download and follow the instruction in the FS26_4.4_1.0.0_D2209_Release_Notes, which can be downloaded from NXP.com. Please see below.
Go to:  https://www.nxp.com/
You must be registered and signed in the NXP.com
Click on: My NXP Account.
Click on: Software Licensing and Support
Click on: View accounts
Click on: Product Search and in the search box write: FS26_4.4_1.0.0_RTM_D2209, press Search
Download the Release_Notes.pdf
With Best Regards,
Jozef
4,335 次查看
julian-quindt
Thank you for pointing me to the release notes. Will install S32DS and try the non-AUTOSAR instructions.
Apparently the non-AUTOSAR approach also assumes usage of S32K3? Could you add some information on usage with the TMS570? The respective application note on the TMS570 does not contain details on driver aspects.
What is the expected way to use the FS26 in conjunction wihtt a TMS570 with respect to the driver?
E.g. Am I supposed to generate a plain C driver for an S32K3 using this driver package and port that over to the TMS570 (big endian)? Any suggestions welcome.
4,328 次查看
JozefKozon
Dear Julian,
With Best Regards,
Jozef
4,319 次查看
julian-quindt
Have created a ticket, thanks for helping out.
