FS23 V1 output abnormal
1,336 次查看
seerlu
V1 output is abnormal as below waveform:
C1 was VSUP,C2 was VBOS,C3 was V2;C4 was V1(power to MCU)C1 was VSUP,C2 was VBOS,C3 was V2;C4 was V1(power to MCU)微信图片_20260813093846_286_23.jpgV1 without npnV1 without npn微信图片_2026-08-13_095130_111.png
How can I thoroughly solve the problems I am currently facing?
if you want to get more information,please let me know.
13 回复数
1,327 次查看
seerlu
VBOS>3.06V TO V1 UPing used 13.2msVBOS>3.06V TO V1 UPing used 13.2ms
1,329 次查看
guoweisun
You can try to disconnect  MCU with V1 and test it again for example add some loading 50mA.
1,299 次查看
seerlu
This is testing.
by the way, we check the manual and found 19.4.6 V1UVLP monitoring chapter shows "V1 is also monitored for V1UVLP when the device powers up after a wake up from LPON, and during a cold start after TSOFT_START_V1. If, at the end of the softstart, V1 is still under V1UVLP threshold, then the device goes into Fail-Safe state."
does it mean V1 should beyond V1UVLP threshold after TSOFT_START_V1(type,300us)?
in addition ,this V1 abnormal issue happened in low temperature (-30℃ ) and low Vsup power(8v)。in this condition, we increased VSUP to 12V,V1 output OK。
1,296 次查看
guoweisun
A lots of confuse for your test result ,you can see when Vbat< Vsup_uv,the V1 should be stay 0,why your V1 follow up VBAT from 0? I suppose your test waveform yellow is VBAT,Green is V1,am I right?
1,290 次查看
seerlu
Channel 1 was VSUP,C2 was VBOS,C3 was V2;C4 was V1(power to MCU)
1,293 次查看
seerlu
which one indicate V1 follow up VBAT from 0?
current test results show VBOS>3.06V TO V1 UPing used 13.2ms, please check
1,272 次查看
guoweisun
在8V Vin的情况下能否把这个上面圈出来的波形的时间轴放小些,我想看V1启动了多久?
另外12V VIN的情况下也测试下相同的波形可以嘛?
我这里没有高低温试验箱无法做太多的测试只能看你们的结果了。
1,256 次查看
seerlu
我们新测了个波形,在输入12V时也发现V1有时第一次启动是失败的。
这是第一次启动失败的波形V1第一次启动未成功图V1第一次启动未成功图
这是第二次启动成功的波形V1第二次启动成功图V1第二次启动成功图
这个是不是和那个V1 在软启动之后的欠压检测有关联,但是软启动的时间是典型值300,最大值500us。现在为啥感觉是超过500us就启动不起来,低于500us好像就行。
能否帮忙描述下软启动的内容,看手册没有太多描述
1,208 次查看
guoweisun
这个问题大概率是V1 发生了OC在软启动的过程中导致启动失败然后又恢复的这个过程。
解决方案可以外加管子阔流在V1端口然后FS23 OTP的时候把这个功能打开,也可以选择我们的HVBUCK的版本。
要么就是适当的去掉一些输出电容让softstart更顺畅,我建议选择上面两个方案更稳妥
1,205 次查看
seerlu
能否帮忙在解释下softstart过程?
包括这一段“19.4.6 V1UVLP monitoring chapter shows "V1 is also monitored for V1UVLP when the device powers up after a wake up from LPON, and during a cold start after TSOFT_START_V1. If, at the end of the softstart, V1 is still under V1UVLP threshold, then the device goes into Fail-Safe state."”到底是要求什么样的V1启动波形?
谢谢
1,202 次查看
guoweisun
这个图可以解释框出来的上面的是softstart的条件,假如都满足了V1开始上电了进入M5的时序,他的时间是150-500us,假如超过了这个时间还没有启动成功就会进入FS状态然后100ms以后重启这样一个大概的过程
1,215 次查看
guoweisun
1:原理图PIN37不用的话接地。
2:V1的负载电流不大的最大才100mA确认下您那里的负载
3:V1_IN的decouple 电容是1uF.
4: 就像上面这个情况第一次启动不成功第二次起来了能否读取寄存器 M_GEN_FLAG register 看看发生了什么?
先改上面这些看看结果。
1,290 次查看
guoweisun
You can see below circled part.
%3CLINGO-SUB%20id%3D%22lingo-sub-2404380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFS23%20V1%20%E8%BE%93%E5%87%BA%E5%BC%82%E5%B8%B8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EV1%20%E8%BE%93%E5%87%BA%E5%BC%82%E5%B8%B8%EF%BC%8C%E6%B3%A2%E5%BD%A2%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22C1%20was%20VSUP%2CC2%20was%20VBOS%2CC3%20was%20V2%3BC4%20was%20V1(power%20to%20MCU)%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22C1%20was%20VSUP%2CC2%20was%20VBOS%2CC3%20was%20V2%3BC4%20was%20V1(power%20to%20MCU)%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394510i82E8ECD5F0072808%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20260813093645_282_23.png%22%20alt%3D%22C1%20was%20VSUP%2CC2%20was%20VBOS%2CC3%20was%20V2%3BC4%20was%20V1(power%20to%20MCU)%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EC1%20was%20VSUP%2CC2%20was%20VBOS%2CC3%20was%20V2%3BC4%20was%20V1(power%20to%20MCU)%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EC1%20%E4%B8%BA%20VSUP%EF%BC%8CC2%20%E4%B8%BA%20VBOS%EF%BC%8CC3%20%E4%B8%BA%20V2%EF%BC%9BC4%20%E4%B8%BA%20V1%EF%BC%88MCU%20%E7%94%B5%E6%BA%90%EF%BC%89%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20260813093846_286_23.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20260813093846_286_23.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394511iD159865FB4830428%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20260813093846_286_23.jpg%22%20alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20260813093846_286_23.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22V1%20without%20npn%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22V1%20without%20npn%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394513i8067B4D38FDBD353%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_2026-08-13_094757_561.png%22%20alt%3D%22V1%20without%20npn%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EV1%20without%20npn%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EV1%20%E6%97%A0%20npn%3C%2FSPAN%3E%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_2026-08-13_095130_111.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_2026-08-13_095130_111.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394514i79D268FB0C8295C5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_2026-08-13_095130_111.png%22%20alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_2026-08-13_095130_111.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%88%91%E8%AF%A5%E5%A6%82%E4%BD%95%E5%BD%BB%E5%BA%95%E8%A7%A3%E5%86%B3%E7%9B%AE%E5%89%8D%E9%9D%A2%E4%B8%B4%E7%9A%84%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E4%BA%86%E8%A7%A3%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405116%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405116%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1786680381549.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1786680381549.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394612i34CF3BF346909405%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1786680381549.png%22%20alt%3D%22guoweisun_0-1786680381549.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_1-1786680552393.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_1-1786680552393.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394613iF2BAE71C1CD5C9CA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_1-1786680552393.png%22%20alt%3D%22guoweisun_1-1786680552393.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%BF%99%E4%B8%AA%E5%9B%BE%E5%8F%AF%E4%BB%A5%E8%A7%A3%E9%87%8A%E6%A1%86%E5%87%BA%E6%9D%A5%E7%9A%84%E4%B8%8A%E9%9D%A2%E7%9A%84%E6%98%AFsoftstart%E7%9A%84%E6%9D%A1%E4%BB%B6%EF%BC%8C%E5%81%87%E5%A6%82%E9%83%BD%E6%BB%A1%E8%B6%B3%E4%BA%86V1%E5%BC%80%E5%A7%8B%E4%B8%8A%E7%94%B5%E4%BA%86%E8%BF%9B%E5%85%A5M5%E7%9A%84%E6%97%B6%E5%BA%8F%EF%BC%8C%E4%BB%96%E7%9A%84%E6%97%B6%E9%97%B4%E6%98%AF150-500us%EF%BC%8C%E5%81%87%E5%A6%82%E8%B6%85%E8%BF%87%E4%BA%86%E8%BF%99%E4%B8%AA%E6%97%B6%E9%97%B4%E8%BF%98%E6%B2%A1%E6%9C%89%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%E5%B0%B1%E4%BC%9A%E8%BF%9B%E5%85%A5FS%E7%8A%B6%E6%80%81%E7%84%B6%E5%90%8E100ms%E4%BB%A5%E5%90%8E%E9%87%8D%E5%90%AF%E8%BF%99%E6%A0%B7%E4%B8%80%E4%B8%AA%E5%A4%A7%E6%A6%82%E7%9A%84%E8%BF%87%E7%A8%8B%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405111%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405111%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%83%BD%E5%90%A6%E5%B8%AE%E5%BF%99%E5%9C%A8%E8%A7%A3%E9%87%8A%E4%B8%8Bsoftstart%E8%BF%87%E7%A8%8B%EF%BC%9F%3C%2FP%3E%3CP%3E%E5%8C%85%E6%8B%AC%E8%BF%99%E4%B8%80%E6%AE%B5%E2%80%9C%3CSPAN%3E19.4.6%20V1UVLP%20monitoring%20chapter%20shows%20%22V1%20is%20also%20monitored%20for%20V1UVLP%20when%20the%20device%20powers%20up%20after%20a%20wake%20up%20from%20LPON%2C%20and%20during%20a%20cold%20start%20after%20TSOFT_START_V1.%20If%2C%20at%20the%20end%20of%20the%20softstart%2C%20V1%20is%20still%20under%20V1UVLP%20threshold%2C%20then%20the%20device%20goes%20into%20Fail-Safe%20state.%22%3C%2FSPAN%3E%E2%80%9D%E5%88%B0%E5%BA%95%E6%98%AF%E8%A6%81%E6%B1%82%E4%BB%80%E4%B9%88%E6%A0%B7%E7%9A%84V1%E5%90%AF%E5%8A%A8%E6%B3%A2%E5%BD%A2%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405109%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405109%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%A4%A7%E6%A6%82%E7%8E%87%E6%98%AFV1%20%E5%8F%91%E7%94%9F%E4%BA%86OC%E5%9C%A8%E8%BD%AF%E5%90%AF%E5%8A%A8%E7%9A%84%E8%BF%87%E7%A8%8B%E4%B8%AD%E5%AF%BC%E8%87%B4%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%E7%84%B6%E5%90%8E%E5%8F%88%E6%81%A2%E5%A4%8D%E7%9A%84%E8%BF%99%E4%B8%AA%E8%BF%87%E7%A8%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E5%8F%AF%E4%BB%A5%E5%A4%96%E5%8A%A0%E7%AE%A1%E5%AD%90%E9%98%94%E6%B5%81%E5%9C%A8V1%E7%AB%AF%E5%8F%A3%E7%84%B6%E5%90%8EFS23%20OTP%E7%9A%84%E6%97%B6%E5%80%99%E6%8A%8A%E8%BF%99%E4%B8%AA%E5%8A%9F%E8%83%BD%E6%89%93%E5%BC%80%EF%BC%8C%E4%B9%9F%E5%8F%AF%E4%BB%A5%E9%80%89%E6%8B%A9%E6%88%91%E4%BB%AC%E7%9A%84HVBUCK%E7%9A%84%E7%89%88%E6%9C%AC%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%A6%81%E4%B9%88%E5%B0%B1%E6%98%AF%E9%80%82%E5%BD%93%E7%9A%84%E5%8E%BB%E6%8E%89%E4%B8%80%E4%BA%9B%E8%BE%93%E5%87%BA%E7%94%B5%E5%AE%B9%E8%AE%A9softstart%E6%9B%B4%E9%A1%BA%E7%95%85%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E9%80%89%E6%8B%A9%E4%B8%8A%E9%9D%A2%E4%B8%A4%E4%B8%AA%E6%96%B9%E6%A1%88%E6%9B%B4%E7%A8%B3%E5%A6%A5%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405034%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405034%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E1%EF%BC%9A%E5%8E%9F%E7%90%86%E5%9B%BEPIN37%E4%B8%8D%E7%94%A8%E7%9A%84%E8%AF%9D%E6%8E%A5%E5%9C%B0%E3%80%82%3C%2FP%3E%0A%3CP%3E2%EF%BC%9AV1%E7%9A%84%E8%B4%9F%E8%BD%BD%E7%94%B5%E6%B5%81%E4%B8%8D%E5%A4%A7%E7%9A%84%E6%9C%80%E5%A4%A7%E6%89%8D100mA%E7%A1%AE%E8%AE%A4%E4%B8%8B%E6%82%A8%E9%82%A3%E9%87%8C%E7%9A%84%E8%B4%9F%E8%BD%BD%3C%2FP%3E%0A%3CP%3E3%EF%BC%9AV1_IN%E7%9A%84decouple%20%E7%94%B5%E5%AE%B9%E6%98%AF1uF.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1786671133675.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1786671133675.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394594i8380DB32E8E62ECB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1786671133675.png%22%20alt%3D%22guoweisun_0-1786671133675.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E4%3A%E2%80%87%E5%B0%B1%E5%83%8F%E4%B8%8A%E9%9D%A2%E8%BF%99%E4%B8%AA%E6%83%85%E5%86%B5%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%90%AF%E5%8A%A8%E4%B8%8D%E6%88%90%E5%8A%9F%E7%AC%AC%E4%BA%8C%E6%AC%A1%E8%B5%B7%E6%9D%A5%E4%BA%86%E8%83%BD%E5%90%A6%E8%AF%BB%E5%8F%96%E5%AF%84%E5%AD%98%E5%99%A8%E2%80%87M_GEN_FLAG%20register%20%E7%9C%8B%E7%9C%8B%E5%8F%91%E7%94%9F%E4%BA%86%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%85%88%E6%94%B9%E4%B8%8A%E9%9D%A2%E8%BF%99%E4%BA%9B%E7%9C%8B%E7%9C%8B%E7%BB%93%E6%9E%9C%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404509%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404509%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BB%AC%E6%96%B0%E6%B5%8B%E4%BA%86%E4%B8%AA%E6%B3%A2%E5%BD%A2%EF%BC%8C%E5%9C%A8%E8%BE%93%E5%85%A512V%E6%97%B6%E4%B9%9F%E5%8F%91%E7%8E%B0V1%E6%9C%89%E6%97%B6%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%98%AF%E5%A4%B1%E8%B4%A5%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22af12f0f0-afa6-40e3-881d-890516697b5a.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22af12f0f0-afa6-40e3-881d-890516697b5a.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394548iBF83D4BA4F561DFD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22af12f0f0-afa6-40e3-881d-890516697b5a.png%22%20alt%3D%22af12f0f0-afa6-40e3-881d-890516697b5a.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%90%AF%E5%8A%A8%E5%A4%B1%E8%B4%A5%E7%9A%84%E6%B3%A2%E5%BD%A2%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22V1%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%9C%AA%E6%88%90%E5%8A%9F%E5%9B%BE%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22V1%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%9C%AA%E6%88%90%E5%8A%9F%E5%9B%BE%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394549i36576A113871CB4A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22V1%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%94%BE%E5%A4%A7%E5%9B%BE.png%22%20alt%3D%22V1%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%9C%AA%E6%88%90%E5%8A%9F%E5%9B%BE%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EV1%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%9C%AA%E6%88%90%E5%8A%9F%E5%9B%BE%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EV1%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%9C%AA%E6%88%90%E5%8A%9F%E5%9B%BE%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E7%AC%AC%E4%BA%8C%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%E7%9A%84%E6%B3%A2%E5%BD%A2%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22V1%E7%AC%AC%E4%BA%8C%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%E5%9B%BE%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22V1%E7%AC%AC%E4%BA%8C%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%E5%9B%BE%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394550iEC18009ED6B1B64C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22V1%E7%AC%AC%E4%BA%8C%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%94%BE%E5%A4%A7%E5%9B%BE.png%22%20alt%3D%22V1%E7%AC%AC%E4%BA%8C%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%E5%9B%BE%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EV1%E7%AC%AC%E4%BA%8C%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%E5%9B%BE%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EV1%E7%AC%AC%E4%BA%8C%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%E5%9B%BE%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E4%B8%AA%E6%98%AF%E4%B8%8D%E6%98%AF%E5%92%8C%E9%82%A3%E4%B8%AAV1%20%E5%9C%A8%E8%BD%AF%E5%90%AF%E5%8A%A8%E4%B9%8B%E5%90%8E%E7%9A%84%E6%AC%A0%E5%8E%8B%E6%A3%80%E6%B5%8B%E6%9C%89%E5%85%B3%E8%81%94%EF%BC%8C%E4%BD%86%E6%98%AF%E8%BD%AF%E5%90%AF%E5%8A%A8%E7%9A%84%E6%97%B6%E9%97%B4%E6%98%AF%E5%85%B8%E5%9E%8B%E5%80%BC300%EF%BC%8C%E6%9C%80%E5%A4%A7%E5%80%BC500us%E3%80%82%E7%8E%B0%E5%9C%A8%E4%B8%BA%E5%95%A5%E6%84%9F%E8%A7%89%E6%98%AF%E8%B6%85%E8%BF%87500us%E5%B0%B1%E5%90%AF%E5%8A%A8%E4%B8%8D%E8%B5%B7%E6%9D%A5%EF%BC%8C%E4%BD%8E%E4%BA%8E500us%E5%A5%BD%E5%83%8F%E5%B0%B1%E8%A1%8C%E3%80%82%3C%2FP%3E%3CP%3E%E8%83%BD%E5%90%A6%E5%B8%AE%E5%BF%99%E6%8F%8F%E8%BF%B0%E4%B8%8B%E8%BD%AF%E5%90%AF%E5%8A%A8%E7%9A%84%E5%86%85%E5%AE%B9%EF%BC%8C%E7%9C%8B%E6%89%8B%E5%86%8C%E6%B2%A1%E6%9C%89%E5%A4%AA%E5%A4%9A%E6%8F%8F%E8%BF%B0%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404462%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404462%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1786608712650.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1786608712650.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394533i686144360D98F5FC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1786608712650.png%22%20alt%3D%22guoweisun_0-1786608712650.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%9C%A88V%20Vin%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E8%83%BD%E5%90%A6%E6%8A%8A%E8%BF%99%E4%B8%AA%E4%B8%8A%E9%9D%A2%E5%9C%88%E5%87%BA%E6%9D%A5%E7%9A%84%E6%B3%A2%E5%BD%A2%E7%9A%84%E6%97%B6%E9%97%B4%E8%BD%B4%E6%94%BE%E5%B0%8F%E4%BA%9B%EF%BC%8C%E6%88%91%E6%83%B3%E7%9C%8BV1%E5%90%AF%E5%8A%A8%E4%BA%86%E5%A4%9A%E4%B9%85%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E5%8F%A6%E5%A4%9612V%20VIN%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E4%B9%9F%E6%B5%8B%E8%AF%95%E4%B8%8B%E7%9B%B8%E5%90%8C%E7%9A%84%E6%B3%A2%E5%BD%A2%E5%8F%AF%E4%BB%A5%E5%98%9B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%BF%99%E9%87%8C%E6%B2%A1%E6%9C%89%E9%AB%98%E4%BD%8E%E6%B8%A9%E8%AF%95%E9%AA%8C%E7%AE%B1%E6%97%A0%E6%B3%95%E5%81%9A%E5%A4%AA%E5%A4%9A%E7%9A%84%E6%B5%8B%E8%AF%95%E5%8F%AA%E8%83%BD%E7%9C%8B%E4%BD%A0%E4%BB%AC%E7%9A%84%E7%BB%93%E6%9E%9C%E4%BA%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404433%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404433%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%E4%B8%8B%E9%9D%A2%E5%9C%88%E5%87%BA%E7%9A%84%E9%83%A8%E5%88%86%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1786601658488.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1786601658488.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394525iE954FAF948DD79B3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1786601658488.png%22%20alt%3D%22guoweisun_0-1786601658488.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%80%9A%E9%81%93%201%20%E4%B8%BA%20VSUP%EF%BC%8CC2%20%E4%B8%BA%20VBOS%EF%BC%8CC3%20%E4%B8%BA%20V2%EF%BC%9BC4%20%E4%B8%BA%20V1%EF%BC%88MCU%20%E7%94%B5%E6%BA%90%EF%BC%89%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404429%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404429%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%93%AA%E4%B8%AA%E6%8C%87%E6%A0%87%E8%A1%A8%E7%A4%BA%20V1%20%E5%90%8E%E7%BB%AD%20VBAT%20%E4%BB%8E%200%20%E5%BC%80%E5%A7%8B%EF%BC%9F%3CBR%20%2F%3E%E5%BD%93%E5%89%8D%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%E6%98%BE%E7%A4%BA%20VBOS%26gt%3B3.06VV1%20%E6%9B%B4%E6%96%B0%E8%80%97%E6%97%B6%2013.2%20%E6%AF%AB%E7%A7%92%EF%BC%8C%E8%AF%B7%E6%A3%80%E6%9F%A5%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1786601048119.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1786601048119.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394523i5B11FC51CA268867%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1786601048119.png%22%20alt%3D%22guoweisun_0-1786601048119.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_1-1786601077374.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_1-1786601077374.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394524i0F7BF06E698BBCA1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_1-1786601077374.png%22%20alt%3D%22guoweisun_1-1786601077374.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E7%9A%84%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%E6%9C%89%E5%BE%88%E5%A4%9A%E4%BB%A4%E4%BA%BA%E5%9B%B0%E6%83%91%E7%9A%84%E5%9C%B0%E6%96%B9%E3%80%82%E4%BD%A0%E5%8F%AF%E4%BB%A5%E7%9C%8B%E5%88%B0%EF%BC%8C%E5%BD%93%20Vbat%20%26lt%3B%20Vsup_uv%20%E6%97%B6%EF%BC%8CV1%20%E5%BA%94%E8%AF%A5%E4%BF%9D%E6%8C%81%E4%B8%BA%200%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%E4%BD%A0%E7%9A%84%20V1%20%E4%BC%9A%E8%B7%9F%E9%9A%8F%20VBAT%20%E4%BB%8E%200%20%E5%BC%80%E5%A7%8B%E5%8F%98%E5%8C%96%E5%91%A2%EF%BC%9F%E6%88%91%E7%8C%9C%E4%BD%A0%E7%9A%84%E6%B5%8B%E8%AF%95%E6%B3%A2%E5%BD%A2%E4%B8%AD%EF%BC%8C%E9%BB%84%E8%89%B2%E4%BB%A3%E8%A1%A8%20VBAT%EF%BC%8C%E7%BB%BF%E8%89%B2%E4%BB%A3%E8%A1%A8%20V1%EF%BC%8C%E5%AF%B9%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%E9%A1%BA%E4%BE%BF%E8%AF%B4%E4%B8%80%E4%B8%8B%EF%BC%8C%E6%88%91%E4%BB%AC%E6%9F%A5%E9%98%85%E4%BA%86%E6%89%8B%E5%86%8C%EF%BC%8C%E5%8F%91%E7%8E%B0%2019.4.6%20V1UVLP%20%E7%9B%91%E6%B5%8B%E7%AB%A0%E8%8A%82%E6%98%BE%E7%A4%BA%E2%80%9C%E5%BD%93%E8%AE%BE%E5%A4%87%E4%BB%8E%20LPON%20%E5%94%A4%E9%86%92%E5%90%8E%E4%B8%8A%E7%94%B5%EF%BC%8C%E4%BB%A5%E5%8F%8A%E5%9C%A8%20TSOFT_START_V1%20%E4%B9%8B%E5%90%8E%E5%86%B7%E5%90%AF%E5%8A%A8%E6%97%B6%EF%BC%8C%E4%B9%9F%E4%BC%9A%E7%9B%91%E6%B5%8B%20V1UVLP%E3%80%82%E5%A6%82%E6%9E%9C%E5%9C%A8%E8%BD%AF%E5%90%AF%E5%8A%A8%E7%BB%93%E6%9D%9F%E6%97%B6%EF%BC%8CV1%20%E4%BB%8D%E7%84%B6%E4%BD%8E%E4%BA%8E%20V1UVLP%20%E9%98%88%E5%80%BC%EF%BC%8C%E5%88%99%E8%AE%BE%E5%A4%87%E8%BF%9B%E5%85%A5%E6%95%85%E9%9A%9C%E4%BF%9D%E6%8A%A4%E7%8A%B6%E6%80%81%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%99%E6%98%AF%E5%90%A6%E6%84%8F%E5%91%B3%E7%9D%80%E5%9C%A8%20TSOFT_START_V1(type%2C300us)%20%E4%B9%8B%E5%90%8E%EF%BC%8CV1%20%E5%BA%94%E8%AF%A5%E8%B6%85%E8%BF%87%20V1UVLP%20%E9%98%88%E5%80%BC%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8CV1%E7%9A%84%E5%BC%82%E5%B8%B8%E9%97%AE%E9%A2%98%E5%8F%91%E7%94%9F%E5%9C%A8%E4%BD%8E%E6%B8%A9%EF%BC%88-30%E2%84%83%EF%BC%89%E5%92%8C%E4%BD%8EVsup%E5%8A%9F%E7%8E%87%EF%BC%888V%EF%BC%89%E4%B8%8B%E3%80%82%E5%9C%A8%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E6%88%91%E4%BB%AC%E5%B0%86VSUP%E6%8F%90%E9%AB%98%E5%88%B012V%EF%BC%8CV1%E8%BE%93%E5%87%BA%E6%AD%A3%E5%B8%B8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22VBOS%26gt%3B3.06V%20TO%20V1%20UPing%20used%2013.2ms%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22VBOS%26gt%3B3.06V%20TO%20V1%20UPing%20used%2013.2ms%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394515i53D7ABCA89356737%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20260813100429_291_23.jpg%22%20alt%3D%22VBOS%26gt%3B3.06V%20TO%20V1%20UPing%20used%2013.2ms%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EVBOS%26gt%3B3.06V%20TO%20V1%20UPing%20used%2013.2ms%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EVBOS%26gt%3B3.06V%20%E8%87%B3%20V1%20UPing%20%E8%80%97%E6%97%B6%2013.2ms%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%B0%9D%E8%AF%95%E6%96%AD%E5%BC%80MCU%E4%B8%8EV1%E7%9A%84%E8%BF%9E%E6%8E%A5%EF%BC%8C%E7%84%B6%E5%90%8E%E5%86%8D%E6%AC%A1%E8%BF%9B%E8%A1%8C%E6%B5%8B%E8%AF%95%EF%BC%8C%E4%BE%8B%E5%A6%82%E5%A2%9E%E5%8A%A050mA%E7%9A%84%E8%B4%9F%E8%BD%BD%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
