FS23 V1 output abnormal
seerlu
V1 output is abnormal as below waveform:
C1 was VSUP,C2 was VBOS,C3 was V2;C4 was V1(power to MCU)C1 was VSUP,C2 was VBOS,C3 was V2;C4 was V1(power to MCU)微信图片_20260813093846_286_23.jpgV1 without npnV1 without npn微信图片_2026-08-13_095130_111.png
How can I thoroughly solve the problems I am currently facing?
if you want to get more information,please let me know.
seerlu
VBOS>3.06V TO V1 UPing used 13.2msVBOS>3.06V TO V1 UPing used 13.2ms
guoweisun
You can try to disconnect  MCU with V1 and test it again for example add some loading 50mA.
seerlu
This is testing.
by the way, we check the manual and found 19.4.6 V1UVLP monitoring chapter shows "V1 is also monitored for V1UVLP when the device powers up after a wake up from LPON, and during a cold start after TSOFT_START_V1. If, at the end of the softstart, V1 is still under V1UVLP threshold, then the device goes into Fail-Safe state."
does it mean V1 should beyond V1UVLP threshold after TSOFT_START_V1(type,300us)?
in addition ,this V1 abnormal issue happened in low temperature (-30℃ ) and low Vsup power(8v)。in this condition, we increased VSUP to 12V,V1 output OK。
guoweisun
A lots of confuse for your test result ,you can see when Vbat< Vsup_uv,the V1 should be stay 0,why your V1 follow up VBAT from 0? I suppose your test waveform yellow is VBAT,Green is V1,am I right?
seerlu
Channel 1 was VSUP,C2 was VBOS,C3 was V2;C4 was V1(power to MCU)
seerlu
which one indicate V1 follow up VBAT from 0?
current test results show VBOS>3.06V TO V1 UPing used 13.2ms, please check
guoweisun
在8V Vin的情况下能否把这个上面圈出来的波形的时间轴放小些,我想看V1启动了多久?
另外12V VIN的情况下也测试下相同的波形可以嘛?
我这里没有高低温试验箱无法做太多的测试只能看你们的结果了。
seerlu
我们新测了个波形,在输入12V时也发现V1有时第一次启动是失败的。
这是第一次启动失败的波形V1第一次启动未成功图V1第一次启动未成功图
这是第二次启动成功的波形V1第二次启动成功图V1第二次启动成功图
这个是不是和那个V1 在软启动之后的欠压检测有关联,但是软启动的时间是典型值300,最大值500us。现在为啥感觉是超过500us就启动不起来,低于500us好像就行。
能否帮忙描述下软启动的内容,看手册没有太多描述
guoweisun
这个问题大概率是V1 发生了OC在软启动的过程中导致启动失败然后又恢复的这个过程。
解决方案可以外加管子阔流在V1端口然后FS23 OTP的时候把这个功能打开,也可以选择我们的HVBUCK的版本。
要么就是适当的去掉一些输出电容让softstart更顺畅,我建议选择上面两个方案更稳妥
seerlu
能否帮忙在解释下softstart过程?
包括这一段“19.4.6 V1UVLP monitoring chapter shows "V1 is also monitored for V1UVLP when the device powers up after a wake up from LPON, and during a cold start after TSOFT_START_V1. If, at the end of the softstart, V1 is still under V1UVLP threshold, then the device goes into Fail-Safe state."”到底是要求什么样的V1启动波形?
谢谢
guoweisun
这个图可以解释框出来的上面的是softstart的条件,假如都满足了V1开始上电了进入M5的时序,他的时间是150-500us,假如超过了这个时间还没有启动成功就会进入FS状态然后100ms以后重启这样一个大概的过程
guoweisun
1:原理图PIN37不用的话接地。
2:V1的负载电流不大的最大才100mA确认下您那里的负载
3:V1_IN的decouple 电容是1uF.
4: 就像上面这个情况第一次启动不成功第二次起来了能否读取寄存器 M_GEN_FLAG register 看看发生了什么?
先改上面这些看看结果。
guoweisun
You can see below circled part.
%3CLINGO-SUB%20id%3D%22lingo-sub-2404380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404380%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EV1%20output%20is%20abnormal%20as%20below%20waveform%3A%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22C1%20was%20VSUP%2CC2%20was%20VBOS%2CC3%20was%20V2%3BC4%20was%20V1(power%20to%20MCU)%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22C1%20was%20VSUP%2CC2%20was%20VBOS%2CC3%20was%20V2%3BC4%20was%20V1(power%20to%20MCU)%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394510i82E8ECD5F0072808%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20260813093645_282_23.png%22%20alt%3D%22C1%20was%20VSUP%2CC2%20was%20VBOS%2CC3%20was%20V2%3BC4%20was%20V1(power%20to%20MCU)%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EC1%20was%20VSUP%2CC2%20was%20VBOS%2CC3%20was%20V2%3BC4%20was%20V1(power%20to%20MCU)%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EC1%20was%20VSUP%2CC2%20was%20VBOS%2CC3%20was%20V2%3BC4%20was%20V1(power%20to%20MCU)%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20260813093846_286_23.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20260813093846_286_23.jpg%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394511iD159865FB4830428%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20260813093846_286_23.jpg%22%20alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20260813093846_286_23.jpg%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22V1%20without%20npn%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22V1%20without%20npn%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394513i8067B4D38FDBD353%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_2026-08-13_094757_561.png%22%20alt%3D%22V1%20without%20npn%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EV1%20without%20npn%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EV1%20without%20npn%3C%2FSPAN%3E%3C%2FSPAN%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_2026-08-13_095130_111.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_2026-08-13_095130_111.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394514i79D268FB0C8295C5%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_2026-08-13_095130_111.png%22%20alt%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_2026-08-13_095130_111.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EHow%20can%20I%20thoroughly%20solve%20the%20problems%20I%20am%20currently%20facing%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eif%20you%20want%20to%20get%20more%20information%2Cplease%20let%20me%20know.%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405116%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405116%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1786680381549.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1786680381549.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394612i34CF3BF346909405%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1786680381549.png%22%20alt%3D%22guoweisun_0-1786680381549.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_1-1786680552393.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_1-1786680552393.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394613iF2BAE71C1CD5C9CA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_1-1786680552393.png%22%20alt%3D%22guoweisun_1-1786680552393.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EThis%20diagram%20explains%20the%20softstart%20conditions%20highlighted%20above.%20If%20all%20conditions%20are%20met%2C%20V1%20starts%20powering%20on%20and%20enters%20the%20M5%20timing%20sequence%2C%20which%20takes%20150-500%C2%B5s.%20If%20the%20startup%20fails%20within%20this%20time%2C%20it%20enters%20the%20FS%20state%20and%20restarts%20after%20100ms.%20This%20is%20roughly%20the%20process.%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405111%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405111%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3ECould%20you%20please%20explain%20the%20softstart%20process%3F%3C%2FP%3E%3CP%3EThis%20section%2C%20%22%20%3CSPAN%3E19.4.6%20V1UVLP%20monitoring%20chapter%20shows%20'V1%20is%20also%20monitored%20for%20V1UVLP%20when%20the%20device%20powers%20up%20after%20a%20wake-up%20from%20LPON%2C%20and%20during%20a%20cold%20start%20after%20TSOFT_START_V1.%20If%2C%20at%20the%20end%20of%20the%20softstart%2C%20V1%20is%20still%20under%20the%20V1UVLP%20threshold%2C%20then%20the%20device%20goes%20into%20Fail-Safe%20state.'%22%3C%2FSPAN%3E%20What%20exactly%20is%20required%20for%20the%20V1%20startup%20waveform%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405109%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405109%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20problem%20is%20most%20likely%20caused%20by%20V1%20experiencing%20a%20startup%20failure%20during%20the%20soft%20boot%20process%20of%20OC%2C%20followed%20by%20a%20recovery.%3C%2FP%3E%0A%3CP%3EThe%20solution%20is%20to%20add%20an%20external%20tube%20to%20the%20V1%20port%20and%20enable%20this%20function%20when%20using%20FS23%20OTP%2C%20or%20you%20can%20choose%20our%20HVBUCK%20version.%3C%2FP%3E%0A%3CP%3EAlternatively%2C%20you%20could%20remove%20some%20output%20capacitors%20to%20make%20the%20softstart%20smoother.%20I%20recommend%20choosing%20either%20of%20these%20two%20solutions%20for%20greater%20stability.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2405034%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2405034%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E1%3A%20If%20PIN37%20in%20the%20schematic%20is%20not%20used%2C%20ground%20it.%3C%2FP%3E%0A%3CP%3E2%3A%20V1's%20load%20current%20is%20not%20large%2C%20only%20a%20maximum%20of%20100mA.%20Please%20confirm%20the%20load%20at%20your%20location.%3C%2FP%3E%0A%3CP%3E3%3A%20The%20decoupling%20capacitor%20of%20V1_IN%20is%201uF.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1786671133675.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1786671133675.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394594i8380DB32E8E62ECB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1786671133675.png%22%20alt%3D%22guoweisun_0-1786671133675.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E4%3A%20In%20the%20case%20above%2C%20if%20the%20first%20startup%20fails%20and%20the%20second%20startup%20occurs%2C%20can%20the%20register%20M_GEN_FLAG%20be%20read%20to%20see%20what%20happened%3F%3C%2FP%3E%0A%3CP%3ELet's%20change%20these%20things%20first%20and%20see%20the%20results.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404509%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404509%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3EWe%20measured%20a%20new%20waveform%20and%20found%20that%20V1%20sometimes%20fails%20to%20start%20on%20the%20first%20try%20when%20the%20input%20is%2012V.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22af12f0f0-afa6-40e3-881d-890516697b5a.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22af12f0f0-afa6-40e3-881d-890516697b5a.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394548iBF83D4BA4F561DFD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22af12f0f0-afa6-40e3-881d-890516697b5a.png%22%20alt%3D%22af12f0f0-afa6-40e3-881d-890516697b5a.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThis%20is%20the%20waveform%20of%20the%20first%20startup%20failure.%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22V1%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%9C%AA%E6%88%90%E5%8A%9F%E5%9B%BE%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22V1%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%9C%AA%E6%88%90%E5%8A%9F%E5%9B%BE%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394549i36576A113871CB4A%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22V1%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%94%BE%E5%A4%A7%E5%9B%BE.png%22%20alt%3D%22V1%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%9C%AA%E6%88%90%E5%8A%9F%E5%9B%BE%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EV1%E7%AC%AC%E4%B8%80%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%9C%AA%E6%88%90%E5%8A%9F%E5%9B%BE%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EV1%20failed%20to%20start%20on%20the%20first%20attempt%20(image)%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThis%20is%20the%20waveform%20of%20the%20second%20successful%20startup.%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22V1%E7%AC%AC%E4%BA%8C%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%E5%9B%BE%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22V1%E7%AC%AC%E4%BA%8C%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%E5%9B%BE%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394550iEC18009ED6B1B64C%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22V1%E7%AC%AC%E4%BA%8C%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%94%BE%E5%A4%A7%E5%9B%BE.png%22%20alt%3D%22V1%E7%AC%AC%E4%BA%8C%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%E5%9B%BE%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EV1%E7%AC%AC%E4%BA%8C%E6%AC%A1%E5%90%AF%E5%8A%A8%E6%88%90%E5%8A%9F%E5%9B%BE%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EV1%20successfully%20started%20for%20the%20second%20time%20(image)%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EIs%20this%20related%20to%20the%20undervoltage%20detection%20in%20V1%20after%20a%20soft%20boot%3F%20The%20typical%20soft%20boot%20time%20is%20300%C2%B5s%2C%20and%20the%20maximum%20is%20500%C2%B5s.%20Why%20does%20it%20seem%20like%20it%20won't%20boot%20if%20it%20exceeds%20500%C2%B5s%2C%20but%20it%20seems%20to%20work%20if%20it's%20below%20500%C2%B5s%3F%3C%2FP%3E%3CP%3ECould%20you%20please%20describe%20the%20soft%20boot%20process%3F%20The%20manual%20doesn't%20provide%20much%20information%20about%20it.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404462%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404462%22%20slang%3D%22zh-CN%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1786608712650.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1786608712650.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394533i686144360D98F5FC%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1786608712650.png%22%20alt%3D%22guoweisun_0-1786608712650.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EWith%208V%20Vin%2C%20could%20you%20reduce%20the%20time%20axis%20of%20the%20waveform%20circled%20above%3F%20I%20want%20to%20see%20how%20long%20V1%20has%20been%20running.%3C%2FP%3E%0A%3CP%3ECan%20we%20also%20test%20the%20same%20waveform%20with%2012V%20VIN%3F%3C%2FP%3E%0A%3CP%3EI%20don't%20have%20a%20high%20and%20low%20temperature%20test%20chamber%20here%2C%20so%20I%20can't%20do%20too%20many%20tests.%20I%20can%20only%20rely%20on%20your%20results.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404433%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404433%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYou%20can%20see%20below%20circled%20part.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1786601658488.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1786601658488.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394525iE954FAF948DD79B3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1786601658488.png%22%20alt%3D%22guoweisun_0-1786601658488.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404432%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EChannel%201%20was%20VSUP%2CC2%20was%20VBOS%2CC3%20was%20V2%3BC4%20was%20V1(power%20to%20MCU)%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404429%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404429%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Ewhich%20one%20indicate%20V1%20follow%20up%20VBAT%20from%200%3F%3CBR%20%2F%3Ecurrent%20test%20results%20show%20VBOS%26gt%3B3.06V%20TO%20V1%20UPing%20used%2013.2ms%2C%20please%20check%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_0-1786601048119.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_0-1786601048119.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394523i5B11FC51CA268867%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_0-1786601048119.png%22%20alt%3D%22guoweisun_0-1786601048119.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22guoweisun_1-1786601077374.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22guoweisun_1-1786601077374.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394524i0F7BF06E698BBCA1%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22guoweisun_1-1786601077374.png%22%20alt%3D%22guoweisun_1-1786601077374.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EA%20lots%20of%20confuse%20for%20your%20test%20result%20%2Cyou%20can%20see%20when%20Vbat%26lt%3B%20Vsup_uv%2Cthe%20V1%20should%20be%20stay%200%2Cwhy%20your%20V1%20follow%20up%20VBAT%20from%200%3F%20I%20suppose%20your%20test%20waveform%20yellow%20is%20VBAT%2CGreen%20is%20V1%2Cam%20I%20right%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404417%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThis%20is%20testing.%3C%2FP%3E%3CP%3Eby%20the%20way%2C%20we%20check%20the%20manual%20and%20found%2019.4.6%20V1UVLP%20monitoring%20chapter%20shows%20%22V1%20is%20also%20monitored%20for%20V1UVLP%20when%20the%20device%20powers%20up%20after%20a%20wake%20up%20from%20LPON%2C%20and%20during%20a%20cold%20start%20after%20TSOFT_START_V1.%20If%2C%20at%20the%20end%20of%20the%20softstart%2C%20V1%20is%20still%20under%20V1UVLP%20threshold%2C%20then%20the%20device%20goes%20into%20Fail-Safe%20state.%22%3C%2FP%3E%3CP%3Edoes%20it%20mean%20V1%20should%20beyond%26nbsp%3BV1UVLP%20threshold%20after%26nbsp%3BTSOFT_START_V1(type%2C300us)%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ein%20addition%20%2Cthis%20V1%26nbsp%3Babnormal%20issue%20happened%20in%20low%20temperature%20(-30%E2%84%83%20%EF%BC%89%20and%20low%20Vsup%20power(8v)%E3%80%82in%20this%20condition%2C%20we%20increased%20VSUP%20to%2012V%EF%BC%8CV1%20output%20OK%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404386%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22VBOS%26gt%3B3.06V%20TO%20V1%20UPing%20used%2013.2ms%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22VBOS%26gt%3B3.06V%20TO%20V1%20UPing%20used%2013.2ms%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F394515i53D7ABCA89356737%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%BE%AE%E4%BF%A1%E5%9B%BE%E7%89%87_20260813100429_291_23.jpg%22%20alt%3D%22VBOS%26gt%3B3.06V%20TO%20V1%20UPing%20used%2013.2ms%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EVBOS%26gt%3B3.06V%20TO%20V1%20UPing%20used%2013.2ms%3C%2Fspan%3E%3C%2Fspan%3E%3CSPAN%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EVBOS%26gt%3B3.06V%20TO%20V1%20UPing%20used%2013.2ms%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2404383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FS23%20V1%20output%20abnormal%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2404383%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EYou%20can%20try%20to%20disconnect%26nbsp%3B%20MCU%20with%20V1%20and%20test%20it%20again%20for%20example%20add%20some%20loading%2050mA.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
