DC Input with TEA2209T
ElektroCat
Hello. How does the TEA2209T behave with a 24V DC input? Will the GATEHL and GATELR pins be driven HIGH?
TomasVaverka
Hello Sankalp,
The TEA2209T will likely not drive the GATEHL and GATELR pins HIGH with a constant 24V DC input. While 24V is technically above the minimum internal "charge state" threshold, the device is designed specifically for AC to DC rectification and relies on voltage zero-crossings to operate its internal logic and supply charging.
BRs, Tomas
TomasVaverka
Hello Sankalp,
BRs, Tomas
%3CLINGO-SUB%20id%3D%22lingo-sub-2342100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDC%20Input%20with%20TEA2209T%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2342100%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello.%20How%20does%20the%26nbsp%3BTEA2209T%20behave%20with%20a%2024V%20DC%20input%3F%20Will%20the%20GATEHL%20and%20GATELR%20pins%20be%20driven%20HIGH%3F%26nbsp%3B%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2342146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DC%20Input%20with%20TEA2209T%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2342146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Sankalp%2C%3C%2FP%3E%0A%3CP%3EThe%20TEA2209T%20will%20likely%20not%20drive%20the%20GATEHL%20and%20GATELR%20pins%20HIGH%20with%20a%20constant%2024V%20DC%20input.%20While%2024V%20is%20technically%20above%20the%20minimum%20internal%20%22charge%20state%22%20threshold%2C%20the%20device%20is%20designed%20specifically%20for%20AC%20to%20DC%20rectification%20and%20relies%20on%20voltage%20zero-crossings%20to%20operate%20its%20internal%20logic%20and%20supply%20charging.%3C%2FP%3E%0A%3CP%3EBRs%2C%20Tomas%3C%2FP%3E%3C%2FLINGO-BODY%3E
