CAN transceiver TJA1145 register initial values
1,745 次查看
NxpCustomer
What are the INIT values of registers in CAN transceivers TJA1145T and TJA1145AT? I am particularly interested in the following:
1. System event status register (address 61h)
2. CAN control register (address 20h)
3. Lock control register (address 0Ah)
In their datasheets, I could find descriptions of each of the bits of these registers, but not the Initial values. Also, INIT values of "reserved bits" could not be found.
Sharath
标记 (1)
1,733 次查看
guoweisun
You can check them in datasheet Table31--Table 31. Register bit settings in TJA1145A operating modes
1,628 次查看
NxpCustomer
Although I still do not find the value of reserved bits in Table31, this is good enough for me. Thank you very much!
1,734 次查看
guoweisun
