About PMIC feedback line artwork
2,631 次查看
111kmw
I have question about PMIC feedback line. (Specially NXP PMIC, FS84 and PF7100)
When we design the PCB, feedback signal is routed using line generally .
How about plane?
For example, there is power plane inner layer, and we connect power plane and feedback pin using via.
Is it ok? or Is it not good? (Because of high current...?)
Please give a answer.
5 回复数
2,619 次查看
guoweisun
Run feedback traces of the regulators in the inner layers to keep them shielded from
the power and noise nodes.
2,616 次查看
111kmw
hi, guoweisun
Thanks for your reply.
Your answer means "Don't connect diretly power plane and feedback pin using via."
Is it right?
2,612 次查看
guoweisun
Correct!
2,608 次查看
111kmw
Thanks, guoweisun!
Could you explain why feedback line should be shielded from the power? (not Switching node)
Because power plane's current can be changed?
Please give me answer!
2,604 次查看
guoweisun
The power path combine with more noise including high frequency/low frequency which will affect with  FB signal.
