AN4849 schematic and code missmatch
Fast
Contributor V
Schematic shows 2 injector bank:
A uses Ls1, Ls2, Hs1, Hs2, current 2
B uses Ls3, Ls4, Hs3, Hs4, current 1.
Yet code has cores using SSSC, same sequencer (AKA ucore) same channel.
The code for Channel correctly swaps current senses with OSSC.
Tags (2)
RafaR
Hi Fast
Thanks for the observation, I will contact the corresponding experts to make a specific review and if necessary begin the correction process.
Have a great day and best of luck.
RafaR
Hi Fast
%3CLINGO-SUB%20id%3D%22lingo-sub-2021345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EAN4849%20schematic%20and%20code%20missmatch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2021345%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESchematic%20shows%202%20injector%20bank%3A%3C%2FP%3E%3CP%3EA%20uses%20Ls1%2C%20Ls2%2C%20Hs1%2C%20Hs2%2C%20current%202%3C%2FP%3E%3CP%3EB%20uses%20Ls3%2C%20Ls4%2C%20Hs3%2C%20Hs4%2C%20current%201.%3C%2FP%3E%3CP%3EYet%20code%20has%20cores%20using%20SSSC%2C%20same%20sequencer%20(AKA%20ucore)%20same%20channel.%3C%2FP%3E%3CP%3EThe%20code%20for%20Channel%20correctly%20swaps%20current%20senses%20with%20OSSC.%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2021986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20AN4849%20schematic%20and%20code%20missmatch%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2021986%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Fast%3C%2FP%3E%0A%3CP%3EThanks%20for%20the%20observation%2C%20I%20will%20contact%20the%20corresponding%20experts%20to%20make%20a%20specific%20review%20and%20if%20necessary%20begin%20the%20correction%20process.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EHave%20a%20great%20day%20and%20best%20of%20luck.%3C%2FP%3E%3C%2FLINGO-BODY%3E
