Hello ag_martinez
Good day!
Unfortunately, I haven't used the simulator you're using, so I can't make a complete comparison, but from what I can see, I can tell you the following:
In ADS/AWR, the original layout includes:
- tee discontinuities,
- mitered bends,
- open-end effects,
- coupling effects.
Furthermore, I understand that the AWR simulation "takes into account" the parasitic effects that may be present in the package.
The image quality of your schematic is a bit blurry and doesn't allow me to see all your components correctly, but in short, AWR takes into account many more effects that can occur in the components, which makes it more difficult (and I don't recommend it) to create an accurate representation manually in other simulators.
We apologize for any inconvenience this may cause.
I hope this information has helped you, please let me know if you need help with anything else.
Have a great day and best of luck.
