MCU-Link Debug Probe
5,455 次查看
willychou
Hello.
When I use MCU-Link to proram my own board,the board need to connect  power to supply voltage,MCU-Link will  sense Vref(voltage on board) to check the voltage is 3V or not.
If I want MCU-Link provide its own voltage,not to sense Vref but supply 3v to the board,can I directly link the U2(power supply) and J6's 3V3?
Thank you so much.
Sincerely.
5,433 次查看
5,434 次查看
5,448 次查看
Hui_Ma
Could you help to let us know which NXP product you are using?
And if your own board is refer which NXP solution? If yes, which solution you are referring?
Thanks.
Mike
