run elf image on P2041RDB
2,214件の閲覧回数
emintz
Hi all,
I work with GHS Integrity RTOS. The loader is u-boot. My goal is to run a kernel (as uncompressed elf format) stored in NOR flash.
How to solve that ? (compressed version works well but this is not the issue)
Eli
2 返答(返信)
1,899件の閲覧回数
sinanakman
Senior Contributor III
Hi Eli
How are you preparing the uncompressed uImage that
you are having trouble with ?
Sinan Akman
1,899件の閲覧回数
emintz
Hi Sinan,
The problem has been solved:
My mistake was in u-boot command parameter - bootelf -s 0xyyyyyyy (formerly I used -p)
