a problem when bitbake devel-image(p4080pcie)
1,366 次查看
shanfeifei
According to release-notes-sdk-1.0.pdf,when i was building the image of  p4080pcie on ubuntu 14.04,there came a problem as followed:
freescale@freescale-sdk:~/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-
systembuilder$  bitbake devel-image
NOTE: Psyco JIT Compiler (http://psyco.sf.net) not available. Install it to increase performance.
NOTE: Handling BitBake files: \ (0394/0394) [100 %]
Parsing of 394 .bb files complete (388 cached, 6 parsed). 521 targets, 1 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
NOTE: preferred version 2010.12 of u-boot not available (for item u-boot)
NOTE: Preparing runqueue
NOTE: Executing runqueue
NOTE: Running task 605 of 1738 (ID: 1526, /home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/oe-core/recipes/db/db_5.0.21.bb, do_compile)
NOTE: Running task 608 of 1738 (ID: 1487, /home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/sb-core/recipes/binutils/binutils-oprofile_2.20.1.bb, do_compile)
NOTE: package db-5.0.21-r1: task do_compile: Started
ERROR: TaskFailed event exception, aborting
ERROR: Build of /home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/oe-core/recipes/db/db_5.0.21.bb do_compile failed
ERROR: Task 1526 (/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/oe-core/recipes/db/db_5.0.21.bb, do_compile) failed with 256
ERROR: Function do_compile failed
NOTE: Task failed: ('function do_compile failed', '/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/db-5.0.21-r1/temp/log.do_compile.2837')
ERROR: Logfile of failure stored in: /home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/db-5.0.21-r1/temp/log.do_compile.2837
Log data follows:
| NOTE: make -j 4
| ./libtool --mode=link powerpc-linux-gnu-gcc -mcpu=e500mc -maix-struct-return --sysroot=/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux -fexpensive-optimizations -frename-registers -fomit-frame-pointer -O2 -g0  -o db_archive -L/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib -Wl,-rpath-link,/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib -Wl,-O1 -Wl,--hash-style=gnu -B/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib \
|    db_archive.lo util_sig.lo libdb-5.0.la -lpthread
| ./libtool --mode=link powerpc-linux-gnu-gcc -mcpu=e500mc -maix-struct-return --sysroot=/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux -fexpensive-optimizations -frename-registers -fomit-frame-pointer -O2 -g0  -o db_checkpoint -L/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib -Wl,-rpath-link,/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib -Wl,-O1 -Wl,--hash-style=gnu -B/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib \
|    db_checkpoint.lo util_log.lo util_sig.lo libdb-5.0.la -lpthread
| ./libtool --mode=link powerpc-linux-gnu-gcc -mcpu=e500mc -maix-struct-return --sysroot=/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux -fexpensive-optimizations -frename-registers -fomit-frame-pointer -O2 -g0  -o db_deadlock -L/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib -Wl,-rpath-link,/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib -Wl,-O1 -Wl,--hash-style=gnu -B/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib \
|    db_deadlock.lo util_log.lo util_sig.lo libdb-5.0.la -lpthread
| ./libtool --mode=link powerpc-linux-gnu-gcc -mcpu=e500mc -maix-struct-return --sysroot=/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux -fexpensive-optimizations -frename-registers -fomit-frame-pointer -O2 -g0  -o db_dump -L/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib -Wl,-rpath-link,/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib -Wl,-O1 -Wl,--hash-style=gnu -B/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib \
|    db_dump.lo util_cache.lo util_sig.lo libdb-5.0.la -lpthread
| libtool: link: powerpc-linux-gnu-gcc -mcpu=e500mc -maix-struct-return --sysroot=/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux -fexpensive-optimizations -frename-registers -fomit-frame-pointer -O2 -g0 -o .libs/db_dump -Wl,-rpath-link -Wl,/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib -Wl,-O1 -Wl,--hash-style=gnu -B/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib .libs/db_dump.o .libs/util_cache.o .libs/util_sig.o  -L/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib ./.libs/libdb-5.0.so -lpthread
| libtool: link: powerpc-linux-gnu-gcc -mcpu=e500mc -maix-struct-return --sysroot=/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux -fexpensive-optimizations -frename-registers -fomit-frame-pointer -O2 -g0 -o .libs/db_deadlock -Wl,-rpath-link -Wl,/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib -Wl,-O1 -Wl,--hash-style=gnu -B/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib .libs/db_deadlock.o .libs/util_log.o .libs/util_sig.o  -L/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib ./.libs/libdb-5.0.so -lpthread
| libtool: link: powerpc-linux-gnu-gcc -mcpu=e500mc -maix-struct-return --sysroot=/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux -fexpensive-optimizations -frename-registers -fomit-frame-pointer -O2 -g0 -o .libs/db_checkpoint -Wl,-rpath-link -Wl,/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib -Wl,-O1 -Wl,--hash-style=gnu -B/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib .libs/db_checkpoint.o .libs/util_log.o .libs/util_sig.o  -L/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib ./.libs/libdb-5.0.so -lpthread
| libtool: link: powerpc-linux-gnu-gcc -mcpu=e500mc -maix-struct-return --sysroot=/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux -fexpensive-optimizations -frename-registers -fomit-frame-pointer -O2 -g0 -o .libs/db_archive -Wl,-rpath-link -Wl,/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib -Wl,-O1 -Wl,--hash-style=gnu -B/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib .libs/db_archive.o .libs/util_sig.o  -L/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/sysroots/ppce500mc-linux/usr/lib ./.libs/libdb-5.0.so -lpthread
| ./.libs/libdb-5.0.so: undefined reference to `__txn_getactive'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_regop_42_recover'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_stat_print_pp'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_ckp_desc'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_ckp_42_recover'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_closeevent'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_set_tx_max'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_region_mutex_count'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_init_recover'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_env_create'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_env_refresh'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_findlastckp'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_reset'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_remrem'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_set_tx_timestamp'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_lockevent'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_begin'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_get_tx_timestamp'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_applied_pp'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_failchk'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_activekids'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_open'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_recycle_id'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_record_fname'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_begin_pp'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_recover_pp'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_force_abort'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_getckp'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_remlock'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_commit'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_remove_buffer'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_abort'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_get_tx_max'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_env_destroy'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_stat_pp'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_remevent'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_checkpoint'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_oldest_reader'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_checkpoint_pp'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_preclose'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_add_buffer'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_get_name'
| ./.libs/libdb-5.0.so: undefined reference to `__txn_set_timeout'
| collect2: ld returned 1 exit status
| make: *** [db_dump] Error 1
| make: *** Waiting for unfinished jobs....
| make: *** [db_deadlock] Error 1
| make: *** [db_archive] Error 1
| make: *** [db_checkpoint] Error 1
| FATAL: oe_runmake failed
NOTE: package db-5.0.21-r1: task do_compile: Failed
Waiting for 1 active tasks to finish:
1: binutils-oprofile-2.20.1-r0.2 do_compile (pid 2838)
NOTE: package binutils-oprofile-2.20.1-r0.2: task do_compile: Started
ERROR: Build of /home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/sb-core/recipes/binutils/binutils-oprofile_2.20.1.bb do_compile failed
NOTE: Task failed: ('function do_compile failed', '/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/temp/log.do_compile.2838')
ERROR: Logfile of failure stored in: /home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/temp/log.do_compile.2838
Log data follows:
| NOTE: make -j 4 configure-build-libiberty all
| make[1]: Entering directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux'
| make[1]: Nothing to be done for `all-target'.
| make[2]: Entering directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/intl'
| make[2]: Nothing to be done for `all'.
| make[2]: Leaving directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/intl'
| make[2]: Entering directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/libiberty'
| make[2]: Entering directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/etc'
| for f in standards.info configure.info; do \
|  if test -f /home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/etc/`echo $f | sed -e 's/.info$/.texi/'`; then \
|    if make "MAKEINFO=makeinfo --split-size=5000000 --split-size=5000000" $f; then \
|      true; \
|    else \
|      exit 1; \
|    fi; \
|  fi; \
| done
| make[3]: Entering directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/libiberty/testsuite'
| make[3]: Nothing to be done for `all'.
| make[3]: Leaving directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/libiberty/testsuite'
| make[2]: Leaving directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/libiberty'
| make[3]: Entering directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/etc'
| make[3]: `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/etc/standards.info' is up to date.
| make[3]: Leaving directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/etc'
| make[3]: `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/etc/configure.info' is up to date.
| make[2]: Leaving directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/etc'
| make[2]: Entering directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/bfd'
| Making info in doc
| make[3]: Entering directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/bfd/doc'
| restore=: && backupdir=".am$$" && \
| rm -rf $backupdir && mkdir $backupdir && \
| if (makeinfo --split-size=5000000 --split-size=5000000 --version) >/dev/null 2>&1; then \
|  for f in bfd.info bfd.info-[0-9] bfd.info-[0-9][0-9] bfd.i[0-9] bfd.i[0-9][0-9]; do \
|    if test -f $f; then mv $f $backupdir; restore=mv; else :; fi; \
|  done; \
| else :; fi && \
| if makeinfo --split-size=5000000 --split-size=5000000   -I /home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/bfd/doc \
| -o bfd.info `test -f 'bfd.texinfo' || echo '/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/bfd/doc/'`bfd.texinfo; \
| then \
|  rc=0; \
| else \
|  rc=$?; \
|  $restore $backupdir/* `echo "./bfd.info" | sed 's|[^/]*$||'`; \
| fi; \
| rm -rf $backupdir; exit $rc
| /home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/bfd/doc/bfd.texinfo:326: unknown command `colophon'
| /home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/bfd/doc/bfd.texinfo:337: unknown command `cygnus'
| make[3]: *** [bfd.info] Error 1
| make[3]: Leaving directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/bfd/doc'
| Making info in po
| make[3]: Entering directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/bfd/po'
| make[3]: Nothing to be done for `info'.
| make[3]: Leaving directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/bfd/po'
| make[3]: Entering directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/bfd'
| make[3]: Nothing to be done for `info-am'.
| make[3]: Leaving directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/bfd'
| make[2]: *** [info-recursive] Error 1
| make[2]: Leaving directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux/bfd'
| make[1]: *** [all-bfd] Error 2
| make[1]: Leaving directory `/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/build_p4080n710_release/work/ppce500mc-linux/binutils-oprofile-2.20.1-r0.2/binutils-2.20.1/build.powerpc-linux.powerpc-linux'
| make: *** [all] Error 2
NOTE: package binutils-oprofile-2.20.1-r0.2: task do_compile: Failed
ERROR: Task 1487 (/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/sb-core/recipes/binutils/binutils-oprofile_2.20.1.bb, do_compile) failed with 256
ERROR: '/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/oe-core/recipes/db/db_5.0.21.bb' failed
ERROR: '/home/freescale/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder/sb-core/recipes/binutils/binutils-oprofile_2.20.1.bb' failed
freescale@freescale-sdk:~/P4080-PCIE-SDK-1.0-05-03-2012/QorIQ-DPAA-SDK-20110609-systembuilder$
1,151 次查看
Pavel
This SDK was developed for Ubuntu 8.04 and Ubuntu 10.04.
Test shows that this SDK cannot build image under Ubuntu 14.
Use Ubunu 10.04 for this SDK. There is no problem if Ubuntu 10.04 is used.
Pavel
